Is this flaring kit any good?
sparky7
NewEngland
no not in my opinion. The only flaring tool i will use on automotive stuff is the mastercool hydraulic flaring tool. Makes life a lot easier and saves a lot of time/aggravation
Mike007
I have had that exact kit for 20 years. I'd say it's OK. Not great.
fflintstone
MOFnowhere Mi.
The mastercool set has many admirers, but it is not for a casual user. For a manual one you want a ridged. It clamps the tube in a superior fashion than the standard type in OP.
Ben Buck
S. W. Ohio
K-D tools are a quality product in my opinion. If this is for home use, and your not going to be doing flaring time and time again, I'd say but it. The hydraulic units are nice also, but who am I, just my .03 :beer:
dragonballz
Massachusetts
If you are only doing 2 or 3 flares, get that cheap one. Doing anymore, get the MasterCool. It even does bubble flares that I needed for my Dodge
GeneralDisorder
Flaring is difficult enough without using a cheap tool. I give that a 90% chance of making crappy flares.
GD
DougMN
I have one that looks like that one but doesn't say K-D on it. I have used it alot and it does the job, but sometimes the flare is off center and I have to redo it. Any flare tool will do a bubble flare, it is just an unfinished double flare.
sunshine1639
Eastwood makes a nice one for brake lines but if you are doing just a couple it is probably cheaper to get them already made.
Mastermind
Ypsilanti, MI
i hate that style flare tool. have never managed to make a flare that worked or i was happy with. just did a line 2 weeks ago, had four different brands like that, went to the parts store and bought the pre made lines and put them together. i need to look into the mastercool.
HaroRider
New York
Ill agree a ridged is good enough for a DIY guy.
I fussed around with the cheap one, if you have time an patience you can get a good flare with the cheap ones, but it becomes a pain..
bob15
Northeasten, CT
GD
I have the same kit and have yet to make a bad flare in the 25 or so years I've been using it. My dad has a similar kit and has been using it for 50 or so years without issues. Maybe I'm the first to do it, but if you follow the directions, you won't have issues. Kinda of amazing, but true.
That kit comes in handy when you are under a vehicle and trying to replace a rotted piece of line without removing the entire brake line.
To the OP, buy it. It's not a bad tool.
bob
racingtadpole
The far side of crazy.. but sometimes Australia
I have an identical kit made by Imperial bought as a Blue Point around 20yrs ago. Ive done lines for quite a few old english cars with it (mostly minis and sprites) and its been easy enough to use.
That will make bubbles too, first step in making a double is making a bubble.
