Metal Cold Cut Saw
scratchedup
Fayetteville, GA
I posted earlier on here about a specific cold cut saw and got no response.
Can anyone guide to an intro on them? How do you like it...What is it best for....flat vs tube...how does it compare to a horizontal band saw???
There has got to plenty of folks that have these.
THX
larry_g
oregon
THX
This forum is mainly populated by mechanics and garage guys and this is not a common saw in those places. Try your question at http://www.chaski.org/homemachinist/ or
http://bbs.homeshopmachinist.net/activity.php .
You can also reserch at http://www.practicalmachinist.com/ but they do not act very friendly to beginners. This link is a lot of people in the business so if you search you will come up with good information on cold saws, maybe not that particular one though.
That said I would love to have a cold cut saw. They are a precision tool and give a great cut but blades are expensive and not to hard to ruin. I also don't have any experience running them so what I do know is from seeing them used and reading.
lg
no neat sig line
Jack Olsen
Los Angeles
There's a distinction between dry cut and cold cut saws. I always get it mixed up, but a cold cut saw (I'm pretty sure) is a $5,000+ piece of machinery that used a coolant bath to make machine-shop-like precision cuts. Then there's the $400-ish carbide tip chop-type saws that use low-RPM motors and carbide-tipped blades and are a great replacement for abrasive cut-off saws.
If you're talking about the latter, then they're fantastic. Louder and faster than a band saw, with less set-up. The advantage to a band saw is that you can set it to cutting (even a bundle of stock) and walk away. The nice thing about a dry cut saw is that you can cut steel as fast as you'd cut wood. It leaves a very clean edge and you can take the saw off the shelf, make a few cuts, and then put the thing back away.
I have a Milwaukee 6190-20 that I got bladeless on Ebay for ~$300. I use Freud Diablo metal cutting blades with it and it's one of the most useful tools in my garage. When I had to cut 300 pickets for a wrought-iron-style fence, the thing was perfect for the job.
A horizontal band saw is also a pretty great tool, once you've got it set up and going. It's going to eat up floor space, which is why I sent mine back (small garage). But blades are cheap and you can have a cup of coffee while the the tool does the work. They can be pretty cheap, too. There's a lot of info out there on the web for getting the HF 4x6 saws set up and working very well.
A portaband saw with a Swag Offroad stand is also a great way to cut steel.
scratchedup
Fayetteville, GA
Thanks...great info.
This is FS on C-list
Knuth 250
Bill R.
THX
I don't own one but i use one alot at my friend's wrought iron shop. Its a scotchman and is used with coolant/cuttinglube. There is no comparison to a band saw or a metal cutoff saw. The cuts are not ultraprecise but they are much better than band or cutoff. I'd have one in a second for personal use if i could justify the cost. The blades are expensive but durable if you don't abuse them with crowding or too much pressure on the blade or items not securely clamped down while sawing. I can make ten square tubing cuts in the time it would take me to do one on a bandsaw. and they don't require much deburring after cutting to get ready to weld.
kyrbz
midwest US
I have a Baileigh CS-315 which is around $2300.00. It's been a great saw, and the one time I had a minor problem, Baileigh replaced the part for free even though the saw was long out of warranty. The plastic coolant tank sprung a leak. Baileigh told me they had a bad batch of coolant tanks and were replacing them regardless of machine's warranty for anybody whose tank developed a leak. Baileigh also sells a small 225mm dia. blade coldsaw for as little as $795.00
http://metal.baileighindustrial.com/metalworking/cold-saws/manual-cold-saws
I don't think there is anything better than a coldsaw for cutting tube and smaller solid stock. If you plan on cutting lots of solid stock, I would probably go with a horizontal bandsaw.
Jack Olsen
Los Angeles
With the Knuth, I'd want to know the voltage, RPM, the arbor size and what blades it uses. I think those came with an integrated cooling setup and tank. It's a great saw, but it might also be overkill -- depending on what it takes to get up and running.
scratchedup
Fayetteville, GA
Single phase 220v, RPM 50 (?), I will check on the blade and arbor.
Overkill yes...buy it is sooo fine......
gus1962
Canton, Ohio
Bandsaw beats cold saw , IMO. I have Trajan 712 band saw (trajansaw.com ) now and I used to
have cold saw. For versatility, you should go for band saw.
scratchedup
Fayetteville, GA
Versatility is nice but that is not what I bought or wanted.
I have a very specific application that needs almost perfect cuts with no fuss.
This saw is what I wanted and it works great. :bowdown:
balrog
scratchedup-
What are the four eyebolts on the wood blocks for?
Congrats on the new toy!
scratchedup
Fayetteville, GA
scratchedup-
This Fxxker's heavy...has to use engine hoist to get it off my trailer then I made this little mod using the eyelets to mount it on this old restaurant stand.
The eyelets each connect to a chain (4) total that hooks to the hoist hook.
:rocker:
