My design calls for a 20 ft long steel beam, W12X35, supported at each end by 3.5 inch steel posts. The front post will sit between the two garage doors, the rear post sits in the wall of the stairwell, 4 feet off the back of the garage.
The beam will support the attic floor on one side of the garage @ 8' ceiling height for my workshop upstairs. Their will be a wall built along the top of the beam, all the way to the ridge line. The ceiling joists for the other side will be supported in this wall at 12' for the high bay lift area.
Location is South 'burbs of Chicago.
My questions:
Thanks in advance.
Gavin.
My questions:
- W12x35 is 12" deep and 35 lbs per foot of length, correct?
- All I can find listed online are posts that extend across a 4" size adjustment range. Is this normal? Only ones I've ever seen are one piece. Where can I get a one piece design the right length?
- Any ideas on approximate cost for the 20 ft W12x35? Sources?
- I believe the beam has to be drilled for (2) 2x12s to be bolted into the web on one side, for hangers to support the attic floor on one side of the garage. The joists are not being rested on top of the beam for height considerations. Should I assume that I also need to bolt a nailer to the top of the beam, basically a sill plate for the wall that will sit above?
Thanks in advance.
Gavin.
