Fire&Steel
So I know this question may have an obvious answer. I was thinking of using 1/2" PVC pipe to run air thru my whole shop. Has anyone on here done this? Any tips or ideas would be great.
But I would think iron pipe would blow just like PVC. Im not an engineer and people have been useing iron pipe for years so it mus not be a problem. besides being cheap, pvc wont rust like iron pipe. So that would be a big plus
This brings up another question for me then. I can see cooper not blowing into a million pieses cause its soft and bends. But I would think iron pipe would blow just like PVC. Im not an engineer and people have been useing iron pipe for years so it mus not be a problem. besides being cheap, pvc wont rust like iron pipe. So that would be a big plus
Fire&Steel, it's a discussion that comes up every so often. The answer is straightforward and always the same. PVC is not designed for use with compressed gas. The PVC industry's manufacturing association warns against using it with compressed gas. OSHA doesn't allow it, either.
(Actually, there is a grade of PVC that is designed for use with compressed gasses, but it's significantly more expensive than the stuff you see in hardware and big box stores.)
Black pipe and Harbor Freight PEX are both pretty cheap. I've even seen air lines used for distribution. There are clever ways to do it. But PVC has a history of significant and dangerous failures when used in this application.
Do not use copper that is soldered together. It must be brazed. If you have a fire the solder joints will fall apart and then your air line is feeding the fire.
When are we going to get a thread about using old car gas tanks - half filled with gasoline - as air compressor storage tanks?
Nah, we need another thread on backfeeding the house from a generator via the dryer plug!![]()
That doesn't work?
What's the record for number of posts on this thread topic?
Don't know, and it's probably a toss-up as to which subject (pvc airlines or backfeeding) has generated the most threads on the internet!
I have to ask, there is another thread about "show us your compressors" And in that thread there are lots of guys who have purchased used compressors, some almost 50 years old. Are they not just as stupid as the guy using PVC? That tank could blow at any time.
Wedge
Wedge
Thankyou. And for the record I have not used PVC pipe. I was asking if people do use it. And it seams there are many who do. But as price and safty goes, Im going to use air brake lines.
Also someone said the reason iron pipe does not blow up is its ductile iron. I want to tell them thats wrong. Ductile iron pipe is very pricey and hard to find in anything under 4". Its what we use for water pipe in the ground.
Check out this from a welding forum where the guy thought the same thing.Chances are that if they rust through they're going to spring a leak - not explode in shrapnel...
The pictures alone should give people pause in purchasing and using an old pressure tank.
http://weldingweb.com/showthread.php?p=455570#post455570
