DHill
Hey all,
So I built a garage. I'm in the process of painting it, and all along I've planned to run 2" conduit from the house.
Problem is, I've thought as far as digging the trench, putting in the conduit, and what it should look like. Now I'm starting to buy parts for wiring and I'm starting to get confused. A friend offered some 4/0 aluminum "Triplex" wire at the moment, but now I'm wondering if that's the right stuff. With 4/0 my drop should be less than 0.5%. I want the wire to be intentionally overdesigned in case I want to run more power later, and since this is the only time I'll have the ground all dug up, now is my only chance!
I've looked up gauges from here:
http://en.wikipedia.org/wiki/American_wire_gauge#Table_of_AWG_wire_sizes
I've calculated the drop from here:
http://www.csgnetwork.com/voltagedropcalc.html
Data:
Distance between house and garage: 50 feet
Expected load for garage: 100 A (with possibility for more?)
Conduit size: 2"
Voltage: 220/240 V
Conditions: underground, in conduit
Questions:
1) Grounding rod(s)? Is this necessary or do I ground to my main panel in the house?
2) Conductor type?
3) What does it look like at my main panel? I originally intended to have a 100A breaker in the house named "Garage" --- this breaker would then feed my garage sub-panel which would have yet another 100A main and then several circuits for 110V and 220V.
Garage will power lights, air compressor, saws and other power tools, and welder.
Pics:
rough idea of distance to garage (blank spot near bottom right of door will be service entrance from ground conduit)
entrance of conduit through garage wall
Mock up of LB fitting and service entrance
Data:
Conduit size: 2"
Voltage: 220/240 V
Questions:
2) Conductor type?
Pics:
