Bevis
where can I find a good heavy duty type deadbolt?? It's for a steel door that will lead into my tool room/ enclosed shop area.
Don't forget, the door bolt is only as good as the door frame it goes into.
I've been trying to decide on going to a keyless deadbolt of some kind. Either a combination lock-type, or the cool new "fingerprint" type. Schlage and others sell it and its the same/not much more than the combo-type. Because I have two young boys, I always lock my shop, even if I'm just going in side for a while and it'd be a lot easier without a key in every pocket!
Which is why it is just as important to make it as difficult to go out a door/window as in it -- e.g. a dead bolt that requires a key on both the inside and outside.With the plethora of cordless cutting tools available locks can easily be bypassed by cutting through the walls, including 2x4 studs in a matter of minutes. ...
That was my point exactly. Almost every garage I've seen on this site is vulnerable to a two person team with a sawsall and a van/panel truck that looks vaguely like a plumbing/AC contractor's truck. Thief #1 cuts his way in through the roof and assembles all the "good stuff" right by the garage door. Then thief #2 backs the van/panel truck up the the garage door. They quickly load up the "good stuff" and drive off after hitting the door closer. The only outward evidence of the theft is a small hole in the roof which is probably not very visible except by the neighbor(s). Besides right next to the hole is an empty turbine vent box he took up there in case someone heard/saw him cutting his way in.Excellent point. Unfortunately most garages/shops have at least one overhead door. These are much harder to secure in an attempt to make it difficult for the crooks to get bigger things out. I agree that the structure should be as anti-crook as possible. However, I still believe a fully functioning and monitored alarm is required.
Well there you go. I can now claim my non-running cars aren't junk, they're part of my ultra-sophisticated security system....then drove the car through the locked garage door when they wanted out....
