SGKent
I have two Kohler toilets about 10 years old. They are low flow. They came with rather quiet fill valves - the typical kind you get in a HD or Lowes - tube with a float that sits around it and rides up and down. The issue is that the toilet tanks take forever to refill. I run about 60 PSI in the house lines so it isn't low pressure. I would say that from empty to full is 7 to 8 minutes. Very quiet but just too long. Does anyone who works with professional plumbing have a recommendation of a brand that refills quickly and is quiet within reason?
I also have a second question no one has been able to answer. The pipe the toilet sits on is about 3 -4" as I recall. The toilet has a ceramic flange at the base that is much smaller than the pipe or the wax rings - the opening size approximates a wax ring style with the horn. Even a wax ring with a horn is angled towards the hole. What it its purpose other than to cause the toilet to get plugged? It is a 90 degree lip so anything hitting it is going to get stuck. I looked when the toilets were installed to see if maybe the flange was perforated etc so one could break it off for larger pipe but that flange is cast and any attempt to remove it would fracture the toilet. Any ideas what the purpose is?
