Piper
Hey fellas
Here's my new machine...http://newsroom.lincolnelectric.com/News+Releases/power+mig+256.htm
it has dials for the wire speed which you can increment by "1" and voltage that goes from 1 to about 25 I think.. I've not run it higher than about 22 for some heavier stuff I was fiddling with. Mind you, I just got this new welder a week ago so I'm still experimenting.
On another forum (weldingweb) I've had lotsa guys suggesting as a trailer requires structural welds, which I agree, and the stock is 1/8" so it's not like I"m going to burn thru it doing a vertical up weld, that I should be doing vertical up for sure. When I spoke to my local machine shop where I bought the welder and metal stock. He also builds a lot of trailers and said he always uses vertical down... so..
I'm still gonna try and fine tune my welder a bit more and run a little cooler/slower and see if I can get my vertical up a bit nicer.
to koditten (Kirk) for this pretty nice write-up about building a trailer.
