Looking for an extra long multimeter lead with battery clamp...
SKAutomotive
Rhode Island
Teacher at my electrical theory course at the dealership has one, it's a black test lead that plugs directly into the DVOM and is about 20 feet long with a battery post (jumper cable style) clamp. He doesn't remember where got it, and I am having a hard time finding one myself. Any help or links would be appreciated.
Not sure if it matters, but it will be used with a Fluke 115.
ndoran
I'd rather not cut and solder wires and potentially add resistance, if I don't have to.
I assume you are saying you are not confident in your ability to make a good soldered joint. If so look at this as an opportunity to improve your soldering skill. After all you have the meter to test the lead you made.
joedodge
Tampa, fl
Made mine myself and I do a lot of electrical driveability work do a nice solder job and always check your leads touching them together before checking continuity so you know what you got and subtract that from ur total. And obviously youl know if you have a good ground
SKAutomotive
Rhode Island
Not what I am saying at all. I actually am more than confident of my soldering skills. Without being too prideful, I know I can solder better than most.
Recent soldering job example:
I would just prefer the one this guy had as it was task built and seamless.
theoldwizard1
SE MI
Pomona (owned by Fluke) is the largest supplier of patch cords, banana plugs, jack, etc.
The longest "stock" cords are 6' (72").
They do sell the very flexible silicone insulated lead wire in 50' lengths (Black 6733-0, Red 6733-2). They also sell sheathed banana plugs (Straight 6383- , 90° 6729- )
greasemonkey44
memphis
ive seen them made; but i usually just use my power probe, mash the go switch and see if you get a voltage drop while cranking
joedodge
Tampa, fl
I gotcha I do emergency vehicle work a lead made like that makes a huge difference. Be careful using the battery as a ground if checking reference circuits and such. Module hosts are good grounds also
Lotek
Los Angeles, Ca.
Now do that thirty six times on your back up under the dash with a flashlight...
Seriously though, making your own tools is good practice, and a lot cheaper.
SKAutomotive
Rhode Island
I can make joints almost as clean as that in those situations, if not I rely on a pigtail twist. But, when making my own tool, I will be able to sit comfortably and make a joint like that each time.
joedodge
Tampa, fl
But can u upside down underwater on fire......... In all seriousness is make one if I was doin it again its made ur way for what u need ul be happiest
SKAutomotive
Rhode Island
Just because your response is logical doesn't mean I have to agree. Now once this hurricane goes away, I will head over to the local parts store and get some wire, an alligator clip and some sacrificial probes.
joedodge
Tampa, fl
How's the weather up there where are you at? I'm in florida I'm sorry your dealing with that man
SKAutomotive
Rhode Island
Not bad actually, was definitely blown out of proportion for my area. We had some rain and up to 60 mph gusts, but right now, during the time they claimed we would be hammered to pieces, it is quiet, no rain, no wind, I even have a window open. Lost power for 3 minutes and that was it.
It's much worse a little further south though, I feel bad for the people in NJ.
joedodge
Tampa, fl
Ya my gf family is there its pretty bad at least its cool at ur area man. One young tech in a rough buisness and economy to another make them tools or make sure you get a good deal if u buy them man. I will say snap on leads **** there rubber insulation crumbled bad
SKAutomotive
Rhode Island
Yeah, I hear you on the SO leads, I had a used SO meter for a bit that I got cheap before I bought my Fluke.
Any advice on how to get a raise so when you are flagging 20 hours a week all winter you can at least survive through it?
joedodge
Tampa, fl
Man I wish I had the magic answer for that. If you don't mind doing emergency vehicle work city count and private agencys are steady that's where I'm at now and I really enjoy it. Also worked in transit bus fleet moving to emergency and medium/heavy duty work pays better than cars in Florida at least
