I can't find unfaced 24". Is there any reason I should not use Kraft faced with paper facing the (existing) drywall?
New construction with 24" spacing in ceiling already drywalled. In Michigan and will be heated to 60-65f. Walls already done with vapor barrier. I want to use batts so that I can do an hour here, an hour there for install, for easier access under it, and so I don't need soffit baffles.
