nissan_crawler
This, right here, is EXACTLY my point! Dryer outlet/ghetto hookup CAN be safe, but why risk it? God forbid you get injured or killed and someone else has to turn off your generator there is a chance of a lineman, or several, being killed. Doing it "right" is not that expensive.
Bottom line is, if you can't afford a $200 transfer switch, you probably shouldn't have bought a generator and a home in the first place.
I tried, city said no. Now what? Of course, that was a few years back, I should check again. the only way I can install one is if my generator will power the whole house at once, otherwise I have to pick a few circuits, which does me absolutely no good.
Here we go again!
"As you pointed out, running through a transfer switch is still backfeeding, it just ensures that the main is disconnected - which is a good thing".
Not even close - it's an "alternate feed", not a "backfeed".
As to the rest:
He meant in regards to the main breaker and people saying that just throwing the main isn't safe enough to prevent backfeeding the line, when that's exactly what the interlock kit does.
minor technicality
