Air line question
Iroc-Z
New Germany, MN
So I scraped some money together to put an air system in my garage. I have a 60 Gallon 2 stage imc compressor from 1992 that I restored. Picked up a 3/4 regulator/water regulator. I went out an picked up 3/4 copper pipe for the whole garage. Here is my question. I picked up Type M copper before I read anything on it. Should I return it and get the thicker copper pipe? Or should I just go with it? I looked around my work at the copper lines and found both the red type copper and blue type copper lines. I have never had a problem with any of the air lines at my shop. What would you guys do?
csp
Franktown, CO
Brazed joints are recommended.
I find this recommendation interesting based on the idea solder melting in the joints of the copper during a fire, but what about that hose reel that so many have plumbed into their air line setups?
Call me crazy but I'm pretty sure that hose is the weak link in a fire. It's also probably safe to assume that not everybody has a shutoff in front of their hose reel, or if they do, that they shut it off after every use.
akdiesel
Wasilla, AK
Most of these rulings / laws are set up for buisenesses via OSHA and other organizations, but they give good guidelines to follow for your own safety as well.
As for your type M copper pipe, it will be fine provided your psv and pressure switch are working correctly.
billsr4
you can use 3/4 pvc rated a 350 psi and its a lot easier to work and a lot cheaper.
Angelfire
New Mexico and Ireland
The copper.org link was an interesting read. Seems there really is validity to having soldered joints being weaker than the pipe, particularly if a 50/50 type solder was used. At a temp of 150, which is highly conceiveable near the compressor, the max working pressure is 150. Compare that with brazing which is ~3 times that amount. Just interesting is all....
darkk
Willimantic, Ct.
See I have heard that water psi is different the air psi. Not sure if that is true.
Pressure is pressure, 5 PSIG is 5 PSIG Air or water. If you used pex tubing it does not explode like rigid pvc....and it's cheap to buy, easy to install.
larry_g
oregon
What makes the difference is stored energy. Compressed air contains a lot of potential energy and that is what causes the 'explosion' when the line or tank ruptures. When a line or tank containing fluid under pressure ruptures the fluid flows out but since it contains no energy it does not 'explode' or more correctly expand at a high rate of speed. That is PART of the reason that PVC can handle water safely but not gasses.
lg
no neat sig line
RCStocker
Indiana, California, Australia
I have used PVC pipe for 30 years in my own shop. I never had more than 120 psi.
PVC is not allowed at all in a commercial shop. When I went to a 2 stage compressor with 175 psi I changed to copper pipe.
If you have see all the pictures of blown PVC you would not use it. I have 2 cousins and an Uncle that are doctors. I should say were. They have all passed on now. They told me about people having the PVC lines blow. One patient lost an eye. PVC gets old and brittle. If it is in the sun it only takes several years until it snaps when you cut it.
For a small home compressor PVC is a great way to go but you did not hear it form me. Do not put it in a commercial shop of any kind. I don't think there is an insurance company that will honor their policy if you use PVC. It does not meet code. Remember code is a minimum standard you can always make things better.
hidollartoys
K. C. Metro area
Not entirely true. Air is considered a "compressible" fluid and water is considered a "non-compressible" fluid. Each have different characteristics when under pressure. And thus the rupture reaction will be different. also there is the mechanical differences in each when flowing in a pipe, I.E. water hammer, weight, etc.
Bwana
Santa Fe, NM
Why not go with Black Pipe,it's cheaper.
Apparently not anymore. I'm replacing my PVC system with copper. Prices yesterday at Lowe's had black pipe at about $2/foot, copper at about $1/foot. Really surprised me, what's up with that?
Edit: BTW, I had two sections of PVC splinter as I was cutting them out so I think it's a good idea to replace it
akdiesel
Wasilla, AK
A side note about PVC or rather ABS. I know the two are different material but I was informed by a house inspector a month ago that referenced some ABS we had to replace in the house that was leaking. The pipe had about a two foot long split. Thought it was due to some of the Skin So Soft product the renter had been using, but he said that back in the late 80's the manufacture of the ABS had a known fault in the product where the seems were and simply sent it to Alaska (that other third world country) to pass it off. This was when the house was built. Sorry for long spew, but some tidbit of info and could also reflect PVC.
