Epoxy on the cheap: Please Help
apache67
Howdy Guys,
I recently relocated from Houston to Atlanta. I am leasing my house here in Atlanta.
Even though I am leasing, I would still like to have a decent garage space to tinker in for my man projects, etc. However, I don’t want to spend a fortune on somebody else’s house (the owner). Can someone recommend an epoxy floor plan on the cheap when it comes to the hardware and the process? Preferably, something more than just the HD or Lowe's epoxy one typically sees in these stores.
Thanks Much!!!
GG
Garage Flooring
Grand Junction, CO
:eyecrazy: I am not a fan of cheap epoxy, you can get Quikrete or Rust-Oleum at your local Home Depot or Lowes. For very little more you can go with a good product like Legacy or Epoxy Coat.
I also wonder if you've considered the work that has to go into an epoxy. Perhaps you should consider one of the many garage flooring products that you can take with you when you leave.
dcs Inc
Indianapolis, Indiana
Can't help ya. Why not just clean it up and apply an acrylic sealer? Cheap....er I don't use that word... much less expensive than an epoxy system. You'll get a good floor system that's easy to clean, fairly resistant to chemicals and has a decent abrassion resistance. Now I'm talking about our products, CSS emulsion. A 53% solids acrylic laced with MMA. Nothing even comes close to it. Depending on your location, you can find a distributor near you. It would be expensive to ship because it is a solvent based product. Good luck with what ever system you choose.
A
apache67
Can you provide me with some specifics? Prep work, typical costs, etc?
Thanks Much!
Steves32
I own lots of property & if a tenant epoxy'd my garage floor with some cheap **** w/o my permission, there would be hell to pay.
Last thing I want to do is grind off a floor after tenant moved out.
You need to run your plan by the owner 1st.
Elite Crete Australia
Australia
This. Don't go and mess up someone else's property with some off the shelf big box store garbage epoxy. Chances are you're going to screw up on your first install anyway and if you are using some cheap junk "epoxy paint" the likelihood of you screwing up will be magnified.
A
apache67
Couple of people here, yourself included, should temper their assumptions. I don't want nor need your assumption(s) outside the scope of the OP question.
Capice?
Shea
California
Actually Gene's suggestion about an acrylic sealer isn't a bad idea. It is inexpensive and easier to prep for than epoxy. Here is an article on the benefits of an acrylic sealer if you are interested. It might fill the bill for a rental property.
ddawg16
S. California
Capice?
It is frowned upon for a newbie to cop an attitude like that.....
Akin to a new guy at a job walking in and telling everyone else how to act......
As already mentioned....your pretty much on your own now....
AlphaGarage
Every Garage, AnyTown, USA
I'll just point out that one of our clients was the handy man for an apartment management company and he called to find out how to go about fixing/replacing a tenant installed floor gone bad, lifting and peeling. He ended up grinding and refinishing the floor, from what I could tell the re-do was at least partially funded by the tenant's security deposit.
KPSquared
Wetaskiwin, Alberta, Canada
Just use whatever spraypaint you can find at Wal-Mart. . .
I think I might add your response to my "how to commit internet suicide" book. . .you nailed it. . .
"Capice" Hahahahahaha. That was the best part. :screwy:
A
apache67
Whatever:rolleyes:
A
apache67
Thanks Shea
+1 for acrylic sealer or for Parking Pads that you can take with you. I would also be very grateful to a tenant that finished my garage floor.
We just went through a terrible experience with a tenant. We have had some good ones as well. I say good for you if you are willing to make an improvement that their next tenant will enjoy --and might even help them rent the house quicker.
I think we also need to correct a few folks. You talked about epoxy on the cheap not cheap garage floor epoxy :beer:
Falcon67
Merkel, TX
Check the Kelly-Moore dealer for KM-15. Epoxy, cheap. Still requires proper prep, but I did 960 sq/ft for under $300.
A
apache67
Thanks. I appreciate the benefit of the doubt. I am a renter, and I am renting out the home that I just left. I posted to gather some information about improving my garage space that I am going to be in for the next three years. Not get a lecture, from someone who knows nothing about the arrangements I have made with my land-lord.
Anyways, the densifier-sealer option is looking like a good route to go. I appreciate all the helpful insights!
Cheers,
G
Jimmy Knight
As a former short & long term renter, why improve someone elses property??? does it really matter what the floor looks like when you will be moving in a year?
Falcon67
Merkel, TX
How many years has yours been down? Do much cutting and welding?
Laid Jan 2012. I do some, not a lot. I treat it pretty badly - dragging heavy lumber over it, 3000 lb car on HF rollers - yes, leaves marks. Holding up fine so far and it's not anywhere near the recommended film thickness. I used 3 kits, thinned 10%, and stretched it so much the last 4 sq/ft almost didn't get any. Should have bought 4 kits. ;) Went down easy and so far looks like it's stuck good. Lots of rough spots on the floor, no problem coving those areas.
FWIW - the old shop used a no-name epoxy from Lowes. I stretched that too, covering 480 sq/ft kinda thin. After 12 years of use, it still looked good - just dirty. Lots of warm slicks parked on this floor.
brownbagg
the guy that own the rental house is right, you do any improvement to the basic house without approvable, you automaticly loose your deposit and he can back charge you to return to normal. it doesnt have anything to do with improvement. he in business to make money and now he has a loophole to get more out of you
A
apache67
My plan was just to "surprise" the owner (and acquaintance) with the newly painted latex floor (see the helpful joe's stuff above). I was also contemplating painting the exterior hardy plank a lime green finish as well. You really think the owner will hold my deposit back?
Also, it's "lose" and not loose.
pauloman
Use a moisture cured urethane, like "aluthane' - gallon (under $100) covers about 400 sf on non porous surfaces. MCU coatings are used in places where good prep cannot be done. Aluthane is considered a metallic paint, filled with aluminum and has a light gray color on most surfaces.
LegacyIndustrial
deerfield, IL
Moisture Cured Urethane should receive a primer coat of epoxy unless the substrate is absolutely perfectly prepared.
You will find out how they make saran-wrap if you don't do it right. :(
dandan111
Indiana
I'm not to hard on my floor. No welding. I do have a snow blade for my garden tractor that has been dragged across it. Also the kids yamaha snowmobile has been in and out of the garage a few times. As far a what I use my garage for it just homeowner stuff,woodwork,bike fixing,snowmobile and whatever else I may be into. I coated the floor in the early spring and it made it through a hot Indiana summer with no problems yet.
