Is it OK to splice 2x4 wall studs?
gayler
Lakin Kansas
I know that splicing is common on trusses, but is it ok to splice wall studs? I have nine foot ceiling in my polebarn garage. I'm framing between the columns that are spaced at ten feet. I have lots of eight foot 2x4s. I've been spicing them with plywood and screws. I am alternating the spice. One at the top and the next one at the bottom and so on. This is only holding insulation and OSB so nothing load bearing. I know I am being cheep by not buying ten footers, but all my materials are free. Other than being a cheep *** is there anything wrong with doing it this way?
Ironhorse
Are you doubling them up? or just splicing them?
onewaydave
Down the road from Dorothy and Toto
I have a wall rising from 8' on one end to 16' on the other (actually several). Not load bearing. I just ran 2 x 4s up and sheeted it in. I wish in hind site, I had framed an 8' wall and added a second wall on top of that to fill in. You know, sill plates and such. I also needed better diagonals.
The reason is I am getting cracks in the sheetrock in a pattern that I think is due to my just using up to 16' of 2 x 4. They are very suttle, in fact, invisible to almost everyone but me.
Scabbing 2 x 4 is common, but I've usually seen it done with 2 x 4s not ply. Although I don't see why ply wouldn't be better.
Dave, now, if that isn't a bunch of internet nonsence, I don't know what is. I'm not in the business at all and am just recalling what I've observed. Who knows what qualifications those I've observed had; I have absolutely none.
green.bubbly
Lafayette, LA
Seems like with the extra work you're doing you'd be better off to just buy 10 footers.
His material is free as is his labor. :thumbup:
shoot summ
What is the thickness of the plywood?
If the wall never sees any compression load I would think it would be OK with 3/4" ply on each side of the joint. Will there be drywall on both sides of the framing? I would probably put some horizontal 2x4's between the studs about midway up just as an added support.
Lotek
Los Angeles, Ca.
Here is my uninformed internet opinion. I would splice with 2x4 instead of ply because half of the thickness of the plywood isn't doing anything for you because the grain is going the wrong direction.
wilcolater
Genoa city, wisconsin
Scabbing 2x4s together is acceptable in a non load bearing wall.
It might be advantageous compared to building a sill and plate at 8 foot, you can run mechanicals through the wall without having to drill through the plate.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Splicing will be alright for non load bearing, but instead of splicing, why don't you build your wall eight foot tall with a top and bottom plate, then build a two foot tall wall with a top and bottom plate, then nail one on the top of the other?
Boomer343
For what you are doing I'd put a piece fo 3/8 ply on either side with a shot of wood glue and use my air stapler to attach the ply to the 2 x 4.
94legaleagle
Why does everybody think their time has no cost?
sometimes it's because the worst day in the shop/garage beats the best day at the office - I don't work in my shop for profit, I do it as a hobby and to relax and forget about the real world
bgarrett
If all you are doing is sitting on your *** scrolling through GJ, eating Cheetos then yes maybe his time is free...**** I'm outa cheetos.:lol_hitti
Are you the guy who went to the doctor because his ***** turned orange?:)
Doctor says, "Ive never seen anything like this. Maybe you should bring your wife in so I can examine her."
Guy: "Dont have a wife"
Doctor, "OK bring your gurlfriend in."
Guy: "Dont have a gurlfriend."
Doctor, "What do you do all day?"
Guy: "Oh, just sit around, watch ****, eat Cheetos."
Tim The Tool Man
Lehigh Valley, PA
This is what I would do only because it would actually be quicker than cutting and scabbing all those pieces of ply wood. That said, what you are doing is absolutely fine as long as you keep staggering them. when you sheet the wall glue as well as screw/nail your sheeting onto the studs. If you are dry walling, go with 5/8.
Since you are doing it on the cheap, watch you local Home Depot's dunnage asile. It took about a month or so but I got all my sheetrock for $2.00 a sheet because it was dingged or had damaged corners. Tape and mud hides all that.
WNYflyer
Lockport, NY
If all you will be doing is insulation and OSB it shouldn't be a problem just splicing on the sides. 1' +_ up from top or bottom. Only thing I would careful of is I don't think I would put the wall up tight against the girts that run horizontally from post to post. I think you want the existing girts to deflect/bend on there own so they don't load the new wall when the wind blows on them. Probably not that big a deal though since you are doing OSB rather than drywall with mudded joints.
If you or anyone else have plans in the future to hang shelves. etc off the walls then you probably need to do a better job of splicing and more importantly the members and connections at the top of the wall become much more important and need more planning/thought
As far as building an 8' wall then building a shorter wall on top of that to make up the remaining..................don't do it.
ket-tek
I understand where you are coming from, say one could be working making money during the time he is dicking around with projects and taking much longer than if he had hired it out or bought 'the right' tool/material for the job at hand.
But what you may make vs. what you would spend varies.
As an example I spent yesterday from about 10am-4pm setting up and pouring a small concrete slab between my garage and compressor shed. It would have been $1200-$1500 turnkey from a company, it cost me $225 in materials and $40 to rent a mixer. (I already had a 5 ton pile of excess gravel in the backyard for fill and also lumber/rebar to make the form so that's another case where some of the material was free and a chance to use up some of it)
Could I have made $1300 in that 6hrs instead to pay someone else to do the job? Maybe, depending on what type of job I may have setup for that day, but having a day with no other plans and I knocked it out for under $300 and it's done.
So let's say I did have some sort of work lined up to make the remainder of the money in that time period, I would just hand it over to the guys doing work for me, so it's really no different cost-wise either way.
Just an example. But each cost situation varies and in addition the good feeling of doing something yourself and learning/gaining experience also can have a value in life as well.
G
gayler
Lakin Kansas
I actualy did this on one section, but realized I was using more lumber to do it this way and more work insulating.
ddawg16
S. California
I'm never eating Cheetos again...........
Lkdelta
40 mi.east of syracuse
Because I don't have to reach into my pocket and pull out some money to pay for it, like I would if someone else was doing it for me.
If it was just time that I would have wasted watching Tv, instead became something productive out in the garage...
no way that has a value that I should pay for
Al Bundy
Upstate NY
Time is not free no matter how little self esteem you may have. Time is the most valuable resource there is. Run out of material, go get some more. Run out of money, go earn some more. Run out of time, guess what?
Have a family? Guess what they value the most, your time. Even time that's seemingly wasted with activities like watching TV is not free. Down time is as important as being productive. I watched my father spend his life always having to do things himself regardless of how long they took. Then he died. Life is short. Don't waste it trying to save a couple nickels.
G
gayler
Lakin Kansas
I do agree with you there. I see it more everyday. I'm working on this project for the family as well. So the kids will have a warm place to play in the winter. My boys are three and five.
WNYflyer
Lockport, NY
Ok. Nobody else did, so I have to. Why?
Well not knowing all the details but in general that is poor practice to have a horizontal joint such as that formed at the top plate/bottom plate connection unless that joint is tied off from moving perpidicular to the wall. Without that joint being tied off or the top/bottom plates be bulked so they span from post to post then the wall is "structurally" unstable due to the joint being unstable.
Yes building the shorter wall on top of of the 8' wall can be done but to be done properly you really need to know what you are doing and most do not have that knowledge. It is best for the layman to just stay away from doing that unless they are guided correctly.
A few on this board have discussed the case where the gable end of their garage has essentially been built like that. The say 9' high wall is stood up with a top plate and then the triangular gable portion is constructed with a bottom plate attached to the lower wall top plate. Very bad practice unless the top plate/bottom plate joint is tied back to something substantial to keep that joint stable.
Again I am generalizing since I don't know all the details but in this situation the risk of any future problems is much higher with the tall wall/short wall construction that simply splicing on a 1' section to get you up to height. Of course with only OSB and insulation the risks are pretty minimal but that doesn't excuse poor practice.
Tim The Tool Man
Lehigh Valley, PA
Sorry, don't want to start anything but you are completely incorrect. I don't know if you have been in the construction trade or not but with what the OP described there is absolutely no issue with him abutting a 2' wall to an 8' wall. This is not a structural/load bearing member or anything like that. It will only act as a non-load barring partition wall. Tying it to the header or footer would only act to strengthen them. Were this an exterior wall exposed to wind shear, then, no you don't do it, but it is not so he can. And there is no special knowledge needed to connect these two non structural members together, you use an old invention called nails, maybe throw in a little construction adhesive for good measure.
Again sorry, rant over. To the OP, splicing plywood as you described is going to work fine, though I would recommend you use construction adhesive as well.
Mickey O
Chicago, IL
:eyecrazy:
