HoosierBuddy
Hey guys,
So yesterday, I started in on my old mustang changing the timing cover. To do this, the harmonic balancer has to come off the crank shaft. This is a high-reving stroker engine, so I've got one of those high-dollar SFI rated harmonic balancers that is press-fit on the end of the crank.
It's super hard to get off. I have to remove the radiator, fan, belts, alternator, a/c compressor, p/s pump and all the brackets to get room to work. Then I have to heat the **** out of the balancer with a propane torch and THEN get started cranking the balancer off with the balancer puller.
The way it works is it has 1 bolt that presses against the center balancer bolt and it has 3 smaller bolts that thread into the pulley-mounting holes on the balancer. In the past, I've always just cranked away on the main center bolt to pull the balancer off...but yesterday I noticed it seemed to be A LOT easier to back the smaller bolts out, get everything tight, and then use the smaller 3 bolts one at a time to pull the balancer off (moving around in a circle a little at a time).
What do you guys think? Is there a prefered method to using one of these tools? I'm honestly thinking of taking a lathe to the balancer before I reinstal it. I mean....it's a BEAR to get off and even worse to get back on. I'm a big-strong man, and I was flat out worn out by the time I got that thing off...and there was smoke rolling off the timing cover from all the heat I used (propane torch) on the balancer hub to even get it to budge. Jeeze...gots to be an easier way!
Phil
Phil
