HELP Gas spill down drain
RedBengal
Looks like things are fine. I may have over reacted a bit with this post, but I wanted to err on the side of caution. Thanks for the advice. Cool website. I've got to remember this one.
Ray-CA
San Diego CA
I'd run a hose to the drain and flush the line a long time.
Also, don't call the EPA or your City/County fire etc. Haz-Mat fines are HUGE.
Ray
welder4956
Birmingham, AL USA
Keep the soap going while flushing. So make sure house drains get a shot of soap.
Good point! The vapors will be in the piping back to the p-traps on the other drains also.
Perhaps you could drop a match down one of the plumbing vents and clear it out...:scared:
NUTTSGT
Northern Central Ohio
Nice first post.
It's to small to be a reportable incident. Flush it with copious amounts of water.
I'd suggest you close the gas can or put a lid on it. The next it gets knocked over, there might be an ignition source nearby.
1949 caddyman
Arizona
Don't even kid about the match. I worked worked a guy that had yellow jackets around his block foundation. He poured gas down the hole & later put a match to it,blew in the wall in the laundry room in the basement.
R
RedBengal
Some of it never even got down the drain, so I'm pretty certain it was less than half a gallon. I'm flushing the garage drain, and every drain in my house right now. Hitting 'em with soap too.
StevePgh
Pittsburgh, PA
DO NOT ADD DISHWASHING DETERGENT THINKING THIS WILL DO ANYTHING PERMANENT!!! Adding Dawn, while seemingly effective, is a bad idea. Even though it looks like is is breaking up the gasoline, those actions are temporary. The gasoline will reform on the surface later. So even though it may not smell fumy after stirring some Dawn into it, walk away and come back in a few hours and you have fumes because of what I just described.
Erring on the side of caution, I'd call the Fire Department. Enough fumes in a small area can cause an explosion, and it does not take much volume to accomplish that.
Full on disclaimer here. I have absolutely no idea what I am talking about. There is no one alive that can claim he or she has ever followed my advice (coincidence?)
If you unwisely chose to ignore the above advice... Ventilation is the key. Don't let the air sit around. Open that garage door and have a box fan, sufficiently far away blowing across the trap and out the open door. Don't flush water into the trap, this will move your problem (gas/fumes) elsewhere outside the trap. Any sinks/tubs/etc. you haven't used in a while - fill em with water. You don't want dry traps elsewhere in the house. Get out that shop vac and **** the trap dry. If it makes you feel better add some Dawn to the trap and the shop vac canister (set it up for wet use and empty it). After turning off the vac, remove the power source, take the lid off (no fumes in confined spaces), move it outside and dispose of properly (whatever that may be). Refill the trap. Use water this time. :D
Edit: Just saw your last post - less than a half gallon means not much, if any, would have made it past the trap. I'd still **** that trap dry - if you are flushing with a garden hose there is not enough volume of water to force the gas that is laying on the top of the trap downstream.
sharkytm
Pocasset, MA
Blow it out with a shopvac set as a blower... that should blow it out of the trap without the fumes getting to the shopvac (which will result in a big boom). Then refill the trap with water. If you had a compressor with a good sized tank, you could use that to blow it out too.
dlenkewich
Saskatoon, Sk, Canada
Relax man^^. It's silly that you're spazzing about the severity of this, yet you tell him to start a vaccuum motor around gasoline fumes. :headscrat
Air it out, dillute the fuel. Don't listen to Steve. All will be fine.
StevePgh
Pittsburgh, PA
I'd say a boom here is pretty unlikely for many reasons - one of which is the airflow would make the fumes quite diffuse. I just wouldn't want the thing to set around with gas in it and the lid on.
dumper
Oregon
Hahahaha. Too much Beavis and Butthead! I sure miss that show.
koditten
Midland, Michigan
The gas will be sitting on top of the water in the trap. Its lighter than water, so it floats. Wick up the majority with a cotton towel. Then deal with flushing the drain.
StevePgh
Pittsburgh, PA
I told him not to listen to me! The issue with fumes is in the trap itself and the pipes, not in the garage. It was also written when he said nearly a gallon and a very strong odor vs. half a gallon max.
The correct answer answer is to let the pros handle it as opposed to random folk on the internet. If you are dealing with your house and your family, you can take whatever risks you are comfortable with. Me, I'd do exactly what I suggested.
NUTTSGT
In other words, you're giving advice but telling him not to listen to you ? :dunno:
Flush it with plenty of water and be done with it.
jhelrey
MN
All of you are over reacting. Go to bed! Tomorrow, everything will be fine.
slghmmr88
Edmond, OK (way north)
Nice first post.
I'd say pay attention to the Fireman, case closed.
SGKent
Citrus Heights CA
that is about 5 - 8 sticks of dynamite you spilled. Ask any boater about the dangers of spilt gas in a confined aread. Were it me, I might be brave and call the local fire department and ask them their opinion. Keep in mind you may get billed if they come, flush out things and etc. A lot depends on if the system is open and the fumes can dissipate or if it is contained and they will sit there.
dna9656
South Puget Sound, Washington, USA.
The lesson I see here is plain: NO gas in the garage, keep it outside the garage in one of those plastic boxes used to store stuff in on a porch or like item. Ground the thing. OR get electric yard tools, the benefits are plain to see, no gas around, no seasonal headaches getting the engines to start, no maintenance on lelctric stuff like there is on engines.
At work only spills of 5 gallons + are reportable, anyhting less and we clean it up and move on. Have there been spills larger than 5 gallons? oh hell no!
jimindm
Des Moines, Iowa
Sop it up with a towel. Vent it well. Gas does evaporate fairly quickly.
I would also like to know, septic system, or city sewer. Also I would be more worried about what damage is being done to the pipes because of the gas. Is it plastic, cast iron or what? Does the drain just go out in the yard some where?
ydna
I am quite blown away (pun intended) at the massive spazzing out and over reaction throughout this thread!
DIC
I saw a guy at the car wash trying to clean some spilled tar out of the bed of his truck with gasoline and used the vacuum cleaner on it. The vacuum blowed up real good.....:lol_hitti :lol:
bams50
Central NY State
Will those boaters know what 'spilt' means? LOL Just kidding, I know you meant either 'spilled' or 'spit'. Neither one's ideal to do with gas...
Really though, not worth overreacting. Clean it up as mentioned the best you can and move on. The smell will fade soon.
(5-8 sticks of dynamite.):spit::willy_nil:lol:
abnorm
Orlando
""Spilt...verb...a simple past tense and past participle of spill.""
dirttracker18
Slate River, ON
To the OP
FWIW Nuts is a firefighter ( in case you missed his avatar) and likely has both the expertise and experience you want.
His is the nearest to expertise you will find in this thread.
NHBandit
East Tennessee
I'm way behind. I'm still shaking my head over this... "I've heard of people pouring gas down their sinks and the fumes blowing up the hot water heater." Unless your fresh water supply is somehow tied to your septic tank or your basement filled up with fumes how would this be possible ? This went down your shop drain ? Do you smell the gas inside your house or just in the shop ? I agree with the advice to simply flush the drains with alot of water and I'm betting the smell will be gone by tomorrow.
ra42mario
Its less then 100 gallons of gas right? It will be fine.
Working in the auto field, I've seen some big gas spills that get mopped right into the nearest drain.
I actually wonder if many of the forum posters have a clue with reality. This is a forum for tools, which generally means people who work with their hands, and I correlate that with common sense, but I see little of it.
twiggles
Another safe, non combustible way to soak up the gas and water from your p trap would be to use a couple of tampons tied to a string or dowel to absorb the gas and water. Those little things will hold A LOT!
Falcon67
Merkel, TX
My grandad used gas (the real stuff back then LOL) plus a match on red ant beds. Later, with the proper effort to build on the success of your elders, I continued the practice with the addition of a Black Cat or two down hole. :thumbup:
rlitman
Long Island
To the OP
No offence to Nuts (who's advice IMO was right on), but those credentials do not necessarily mean much:
http://newyork.cbslocal.com/2012/11...ing-cars-on-fire-while-trying-to-siphon-fuel/
Anyway, gas fumes are no more flammable or explosive than any other fumes in the sewer. So flushing it down the drain is indeed the best option.
With a hose, you will probably be able to flush down all but a little slick left behind on the surface. If it still smells, you can probably break that up with dawn.
Or, if you want a more "unconventional" solution, you can use something that soaks up gas/oil. Most things you dunk in the water will preferentially soak up water, and won't touch the gas (such as the tampons suggested).
One thing that does work is hair. You could get a fistful of hair, stuff it into a sock, and dunk that. But I suspect dawn will be the simpler answer.
BD1
north side
I never heard of a trap in a garage drain. In the winter it would freeze. What state are you in ?? Some states, county only allow a garage drain to run outside to a dry well or just stub outside. I never heard of a garage drain in a residence being connect to home sanitary system or septic. do you know where the drain goes to ?
My gas cans are the SAFETY TYPE, spring loaded cap, might seem costly but this would not have happened.
