phillips drill bit recommendation
FiendFX
California
Is there a phillips drill bit 2-3 inch long that doesn't slip? I got the milwaukee shockwave the heads are small so they slip or they would wear out the screw. I use mostly phillips #2.
chewy7
WISCONSIN
get some square drive ones and you wont have that problem. get some square drive screws too.
larry_g
oregon
http://www.all-spec.com/products/Tools|Driver_Bits_and_Blades|TOL-75/?filter=MDF8MDk= &brand=Apex
Do you know for certain that the head is Phillips and not Posi drive or some other look alike? Do you know the size of the head 1, 2, or 3? Each one takes a different driver that matches the brand of the head, and all are proprietary. The above link is for Phillips bits and they also show the other styles if you go up a couple of levels.
Here is a link that shows the different drive styles Bit styles
lg
no neat sig line
Holt
Bellevue, Nebraska
Snap on acr bit.
Edit I don't think SnapOn make 2 or 3 inch acr. Try wera diamond head. I myself use the milk shockwave brand and have no issues. I use them on mostly wood screws so if you are using them on machine screws I cannot comment on how well they work.
BrokewrenchLS1
WV
If you're using the wrong size bit (P1, 2, 3, etc), it's going to cam out regardless of the brand you use. Philips will also cam out eventually regardless of the brand you use as the torque required to drive it increases - it was designed to do that.
Torx can't be beat if you need to tighten something down and don't want cam-outs.
F
FiendFX
California
Are the Dewalt phillips bits similar to ACR and Apex? Cuz I really hate the dewalt bits
Stephenw
Utah
Bosch, anti-cam-out, made in the USA. Check the package to make sure they are still USA.
F
FiendFX
California
That's true. Mostly made in china bits. I can get some ACR on amazon for cheap and free shipping. Wonder if they are made in usa?
Holt
Bellevue, Nebraska
I think those will be fine as long as you dont use them in a impact driver. Even so the price is cheap enough you can abuse them and not feel bad
Jack Olsen
Los Angeles
Are you using the bits with a drill or an impact driver?
I got frustrated with stripping through them, and recently got a set of the Wera Diamond Coated Impaktor Screwdriver Bits. They're six bucks a pop, which is a little nuts. But I'm still on the first one.
Here's the cheesy promotional graphic:
