Red Heads
Bronson
Texas panhandle
Now that I have Your attention....:)
I need to put an anchor in My slab in My shop. I only need one, a 3/4 inch ought to be fine. It has been years since I drilled any holes in concrete, but We used to use what We called Red-heads, in the hole, once it was drilled.Do they still make those? I need to go at least 6 inches deep, and want a nut to thread to the exposed shank.
I dont have a hammer-drill. If I cant borrow/rent one in town, does H-F sell a hammer drill? What about the actual bit?
Do I need to epoxy the anchor in the hole, or will the expanding shank hold without epoxy? I only need one hole/anchor, so I am trying to do it as cheaply as possible. Thanks!:beer:
T_Hed
SW Virginia / SW Florida
I used 3/4 redheads when i installed my lift (no Epoxy).
I sold the lift last week and had to cut the redheads out with an angle grinder.
They will not pull out if you install them deep enough.
T
Jack Olsen
Los Angeles
Harbor Freight sells three different hammer drill models.
I have the 1" model (currently $80 or $64 w/coupon), and it comes with 10, 12, 14, and 22mm bits. So if you go that route, you might want to pick a Red Head based on the hole you can drill and save yourself the cost of an extra bit.
They also have a couple of smaller ones (7.5 amp and 4.2 amp), which are $34 and $20 before a 20% coupon.
I'm surprised at how often I've used mine. Aside from drilling holes, it's also good for small demo jobs. I used it to unseat some of the tiles in my shop when I put in the lift, for example.
Bronson
Texas panhandle
You guys are the best! I asked the question, wnet to brush My teeth and feed the critters, came back and already 9 replies...
I bought a H-F hammer drill several years ago, brought it home, plugged it in-and IT CAUGHT ON FIRE. I took it back and have never needed one, until now.
I think I will probably go the H-D rental/redhead route. Thanks!
BD1
north side
Just curious, why only one ???? What is it for ?? Do you know how thick your slab is ? You need to go 6'' ?
saturdaymechanic
Maryland, DC area
I just used some Red Heads this past weekend. I didn't epoxy them either, they seemed to work well.
I was looking at Tap Com anchors and the HD guy said these were the better choice for the job.
Kevin C
Portland OR
http://www.harborfreight.com/power-tools/hammer-drills/3-in-1-1-inch-sds-rotary-hammer-97743.html
I also have the Harbor Freight 1" hammer drill. So far no smoke or fire from it. It's actually pretty well rated on a number of tool forums.
I have had it for about three years and used it about a dozen times. So far it works great. It was cheap enough that it paid for itself pretty quickly.
Kevin
Garyss.smith
Austin, Tx
Bronson
I was raised in Muleshoe and my dad (who was a pharmacist) always drilled the hole with a star drill and put a bolt head down in the hole. then he melted powdered sulfur and pored it into the hold once it solidified it was as hard as the concrete.
Gary
RPH
Michigan Thumb
Any vibration on the anchor? If so use epoxy. We have robots pulling loose, they didn't use epoxy at installation. Big headache!
64Trvlr
Northern AZ
Bronson
Texas panhandle
Thanks, Guys, the job is done. I installed one 5/8 anchor. The local ACE loaned Me the hammer drill, but I had to buy a bit. Total cost of project, $23. thanks for the input!
