Tool storage alternatives- Here's Mine
tool-guy
victoria, australia
Here is, what i think is a neat way to store tools and other items in your shed or garage.
Down here in Melbourne, Australia and i assume other place around the world, certain medications are shipped in plastic crates that are used once. Crate size is approx 360mm long x 300mm wide and 80mm deep and they stack on top of each other.
Best of all you can pick them up for about $2.00 depending on quantity.
Ideal storage for alot of things that aren't overly big but can be painful to store.
I had been using about 40 for storage of different items but had them stacked on a shelf, problem was, every time you wanted something from the bottom trays you had to remove the top trays.
Solution:
Storage box shelving, made out of melamine covered particle board. Each one holds 15 trays and is just under 1800mm high with casters on the base for easy moving. Best of all i had four units made by a neighbour as a contra deal for borrowing a scissor lift, other wise they would of cost about $75.00 each. Still cheap storage in my opinion.
Being plastic you can use a marker to write on the front of them what each one contains. And yes they are quiet stable and can be moved around full.
Currently i have 4 units for a total of sixty crates but i can see more being made for my shed. I thinking of having some made with doors to keep dust out if that becomes a problem.
Hope this gives other ideas.
lilscorpion
Colorado
I've used, and still use, a variety of crates for storage and I think they're fantastic. I really like your idea, it makes for easily access to stuff quickly and you could easily build as many variations as you have crates.
rharman
SoCal
I just bought 6 bins similar to these yesterday as an experiment. Decided to try storing (most of my) power tools without the molded plastic cases.
I bought mine from the local Costco Business Center. They're busboy trays for restaurants. So far, after one day, I think I like it. They're in a tall cabinet in my garage.
DrJaymez
This is absolutely dope. Great idea. I'll have to think about incorporating something similar to this somewhere.
T
tool-guy
victoria, australia
If you're in melbourne, a place over in Tullamarine sells them, if you PM me i'll try and dig up the address. I think they're about $2 if you buy about 100 of them.
sams
S.E Victoria, Australia!
I am also interested in the idea however I am in the S.E suberbs. I will ask my brother who works in a hospital to see if these are available there.
This is a similar concept to my fastener storage:
You and me are thinking alike. You get a massive amount of storage area for a small compromise of floor space.
Jose Cuervo
I made these for my electronics components last year. The containers on the right are from Lowes and the ones on the left are from Harbor Freight. I think I'll build another one for those busboy trays too.
sdavis622
Surprise, AZ
How much for the busboy trays at Costco?
Sent from my SAMSUNG-SM-N900A using Tapatalk
