robe5000
looking at his patent info it would seem his patent is for voltmeter leads, PP3 and voltpro are not test leads, i would say Dan is SOL
You just need a 25 ohm resistor and a microswitch. All this thing does is switch between the resistor and no resistor. The resistor allows about .5 amp of current to flow to B-. The multimeter reads the voltage at the load point. It is designed to make a simple voltage drop test without the load, like a headlight. IT IS THE LOAD. But, it is not the real load which may be much more or much less. You can do a far better test by leaving the load in place and powering the circuit and putting your voltmeter across the suspect wire and looking for the voltage drop of the wire. Different circuits have different allowable voltage drop, depending on the wire gauge, but you will learn from experience what is acceptable and what is not. Let's say anything over .6 V drop is not good for most circuits.
The Waekon device on the other hand is a logic probe, voltmeter, loader, pulser, glitch capture and more. It has actual circuit board with a logic probe circuit, a voltmeter circuit, glitch circuit. You get the picture. It's like comparing a hammer to a nail gun.
How does the volt-pro load both ground and supply at the same time if its only got the one test point?
But the point of these small devices is convenience and speed to bypass using a multimeter for quick tests. Moreover, the multimeter does not have a pulsing logic grab that can show an injector pulse, for example. Thus, the Waekon device would be nice for that function that you can't do with the multimeter. It also has a glitch capture that may not be included in the multimeter or it may be better (faster) than the multimeter. Also, you tell me how you do logic probe functionality with the multimeter? I know how you might be able to do it but it is a pain. The beauty of devices like these logic probes is the connection to both terminals of the battery.
So, tell me the logic probe functionality with the multimeter to see if you would do it the same way I would.
the point I was trying to make is that the multimeter is cumbersome to use compared to a logic probe if you are just probing to see power and ground circuits. To do those tests you detail, which are fine, you have to keep switching your multimeter leads back at known good sources for either power or ground, usually the battery. To see that 0.00V to confirm the wire is a ground you have to go across the wire back to the battery (the known ground). As I said the beauty of these quick type devices is that they have permanent connections to both B plus and minus to do the logic comparison for you.
OK I see your point, but I would counter it with the fact that a good quality DVOM like a Fluke 87/88 fitted with a set of Load-Pro test leads is a more rounded tool as you can use it to make resistance/current measurements as well as voltage/circuit loading and a whole array of other tests.
I will go out on a limb and say I can already see a major flaw in the volt-pros design that no one has been able to answer yet.
Load-Pro loads the entire circuit (ground/supply) using 2 probes one for the supply/one for ground.
How does the volt-pro do this as it appears to only have one test probe??
I've watched Mr. Sullivan's video. In the interest of full disclosure, I am a Patent Attorney.
In my estimation, Mr. Sullivan did himself a real disservice in his attempt to take his case to the "court of public opinion". Although I understand his emotional attachment to his invention, his family and parents, etc. he's alleged that others "stole my patent". He's unfortunately put Waekon in apprehension of suit, such that Waekon may now sue him in a declaratory judgment suit, and force him to prove infringement. Truly bad news because he'd have to prove that they're infringers and defend the validity of his own claims, and spend tons of money on it and wind up a BIG loser when he can do neither. And by the way, Waekon chooses where to sue, which would be very inconvenient to Sullivan. Guaranteed.
He really needed some professional advice before he did this.
I don't know right now. You are saying that it can't load test the ground side it seems. The waekon takes power to ground through its own leads bypassing the connectors ground wire path. So I see what you are saying.
only backwoods ****-holes pierce wires nowadays
...Waekon may now sue him in a declaratory judgment suit, and force him to prove infringement...
I know my electrical knowledge is lacking compared to you two so I might not know what I'm talking about but since the weakon voltpro is hooked up to the battery pos and neg couldn't you touch the probe to the pos side of the circuit to test that and then touch the probe to the neg side of the circuit to test that to accomplish what the loadpro does?
You can't be sued for asking a question.
I haven't use any of these tools, but I have a question with the loadpro. The loadpro is only loading the circuit with the DMM battery? I am not sure how accurate you can perform a loaded circuit test with such low current flow especially with components that required large amount of current. Based on what I read here, I would go with PP3.
I certainly will try. I do have a 13-year bias, but as I say, all tools have ups and downs. My complaint has been that no one was ever willing to really give this thing a chance, because they didn't have the ability to look outside the box. "It's just another Powerprobe..."
I'm shooting a video about ECM power corrosion this week, and I'd planned on showing all 3 tools if I can. It's important to note that the Volt-Pro tests one leg at a time, and it does load the circuit, so it can see corrosion, so it has to load the positive and negative individually using the vehicle supply. If it sees a ground it tests that. If it sees voltage, it tests that. I don't know the Ω thresholds yet.
My problem is I don't think they should be able to build it...
Sounds to me like you need to file a case in Raleigh this week, otherwise you may be defending a declaratory judgment action in Cleveland, where you might not fare as well.
Your problem isn't going to be infringement of that patent, it's going to be sustaining its validity - but you already knew that.
That patent took you a long time, no?
How many times did you add to it?
MrMark - You nailed it. I understand that the tool is insanely simple - that's the reason the patent was so difficult, and why the claims are so broad. Mr. Steinmetz is correct that there are potentially patent ramifications to my video, and I did seek help from my patent attorney before proceeding. Nothing I said about the meeting with Waekon was false. The patent establishes a switched load through leads to a voltmeter. The Volt-Pro has a voltmeter, a load and a switch --- it's pretty clear.
I appreciate the comments made by Mr. Hootbro as well. What I recorded was pretty much stream-of-consciousness, and I edited as best I could. I agree that an emotional appeal is only part of any argument, but it's there nonetheless. If anyone else has fought off bankruptcy for 13 years, taken on 4 step-kids, lost his parents, and lost his family because his sisters took the estate and accused him of theft - and had double-bypass surgery at 46 from stress - AND had to fight what feels like the entire world of pin-headed engineers - feel free to comment on the emotional content of my message. Walk a mile in the steel-toes...
The practical aspect of the patent matter is pretty cut and dried - and Mr. pfarber makes a good point. If I could afford to hire pretty women in bikinis to try and curry sympathy I assure you I would. But - I can't. Instead, I told the truth, as I saw it, and I would be happy to debate Mr. Bauman or Mr. Hart. All tools have advantages and disadvantages. But until you've had to deal with the never-ending annoyance of being a teacher who invented a tool, but who can't talk about about it because people complain about his attempt to sell the tool, even though his 30 years of experience makes it clear the tool is a total change to the basic concept of meter reading --- I reserve the right to question your ability to understand.
And as for Mr. Robe5000 - I actually agree. I have made some money over the past few years, but no fortune. And the first rule of business is that you put it all back into the business. The first 9 years were losing years; the next 4 were better, but that money went to make up for the first 9. Now, 13 years later, I'm actually able to spend the few dollars the royalties bring in. The 6'4" 16 year-old really does eat 7000 calories per day. I don't spend my time crying - I spend it teaching, and the only reason I might have to cry is when I hear some guy tell me that he thinks he's too stupid or undeserving to be good at electrical. I usually don't cry though - I sit him down and start teaching so I can prove him wrong.
Every tool has some value, and some people succeed with Powerprobe. But I'm disappointed that the LOADpro Leads I developed in a class in 1999 and patented in 2002 haven't been better promoted. At $70 people assume it doesn't work, and the tool companies have a harder time seeing a profit. It's a set of voltmeter leads you simply attach to your digital meter, and when you see voltage, you push the LOADpro button and immediately load the circuit to test conductivity.
The Powerprobe hook is $500 and more profitable. For $300 you can get the TMX 589 Tech Meter kit which includes a digital meter, the LOADpro leads, my 200 page electrical book and a one-hour DVD on meter reading and diagnostics.
If you read the voltmeter correctly, you only need to read voltage and load the circuit to recognize if it's open, shorted-to-ground or corroded (the only 3 faults in a single wire).
I know people will argue and say that it can't be that easy, but it it. I've been teaching electricity for 27 years and if there's one thing I understand, it's that people make it harder than it needs to be. The Powerprobe Hook is waaaaaay too complicated and has functions that really aren't all that helpful.
My opinion - but before you slam me (as I expect might happen) watch this and decide for yourself:
