MrMark
bad grounds cause crazy stuff to happen.
The Sullivan device tests both sides of the circuit B+ and B- on the initial test that you see where he plugs into the connector putting the 25 ohm replacement load where the real load was. You need to do some further testing to see whether the B+ path or the B- path has the bad connection or wire (added unaccounted for resistance).
You could do the same thing by putting your test light (the replacement load) where the volt pro leads are connected and then putting your multimeter across the test light to see if any system voltage was dropped other than across the load where it is supposed to be. So, if the system v is 12.6 if you see less than 12.6 across that light the missing voltage was dropped somewhere else in the circuit that it shouldn't have been. If you add 50 ohms, for example, it would drop the voltage across the load down to around 4 volts.
Sullivan's invention, if it holds up, is the clever way he incorporated a load test with voltmeter.
