L5wolvesf
I have been thinking about building a rolling device to store / work on a small race car I am early in the process of rebuilding. Having it off it’s wheels and movable (like on castors) would be really helpful considering the amount of garage space I have to work with.
The idea so far is to build a pair of saw horse style contraptions that would hold the car up about 18” off the floor, roughly the height where I can do some of the work sitting on a folding chair. They would need to be about 4 ft wide (width of the car).
Material wise I am thinking pipe (black, or galv, fence or ?? / possibly used to keep it affordable), threaded (for ease of construction). The car weighs 1500lbs (wet), and with the engine in would be rear heavy.
Is pipe a feasible material to do this with? What diameter would be recommended? Should I calculate the wheel capacity, using 2000 lbs as the full load (for a built in safety factor) divided by 8 (1 wheel per sawhorse leg), or . . ? Are there reasonably priced wheels/castors that can handle the weight? If I build it, how wide of a footprint between the legs on each side?
Obviously, the cost is a factor on this project. If something already exists, or is close to what I am describing that would help too.
Your input IS appreciated.
L
L
