Flank drive or box end?
Danglerb
SoCal
I've got a bunch of different type and brand of wrenches, and while reading something on the Flank drive it started me thinking, I almost never apply a lot of force with any open end wrench switching to box end if I can. Which is the better way to go, given most box end are 12pt?
tjmonsen5
Crystal Lake IL
Box end is always best to bust loose with, but in the situation where the box end wont fit. The flank drive plus really grabs tight. I use them all the time and I have never had one slip off.
chris142
apple valley,ca
I used one of my new flank drive plus wrenches today on a hard to acess bolt and I'm sold! I could only get a small bite on The bolt head but it held onto it and did not slip.
HaroRider
New York
Going around the whole bolt means less chance of stripping. (More surface area)
But like mentioned above sometimes its not an option.
PavelK313
I used my CM raised panel wrenches yesterday to brake tighten a nut for the first time in very long time and couldnt believe how bad they were. Need to upgrade to something better and to something that wont make me go broke.
Jason280
I'm not following you here, but what exactly were you doing? Where you working with a brake line fitting?
jhurless
If you are asking whether or not to bother with the flank drive (plus) open end wrenches or not, I would definitely bother. Box end always gives you more purchase, but as stated above you don't always have that option and in that case, Flank drive is an excellent addition to the open end. I think there is a video on youtube that shows how effective they are if you do a quick search.
PavelK313
Tightening control arm ball joint on BMW. Its 16mm nut and I only had 6 point box wrench. the nut I was working on is located in very tight spot and 6 point box wrench didnt allow me to use full stoke and still being able to reposition it for next stroke. So I tried using open end and it phaking sucked!
D
Danglerb
SoCal
I have both, didn't know that about Flank drive being the box end and Plus the open end version. I just bought the Snapon's in a few sizes I like and noted some had the different open end.
Thanks for the info.
tjmonsen5
Crystal Lake IL
All Snap-on wrenches have flank drive box ends, the plus is just bonus on the open end.
