Most likely.
For years I have been using a die grinder with cutoff wheels. I think today I realized the tool I should be using is a....gasp....cutoff tool.
But after examining these tools the only difference seems to be the cutoff tool has a shield. Is this the only difference? Or does a cutoff tool perform spectacularly better than a die grinder with cutoff wheels?
Reason I ask is I was using 2 today ( a Kobalt and a CH) and they both barely had any balls..
Or...do I just need a bigger air compressor.......
Edit-
Air Compressor specs: CH 125 PSI 5.5 CFM, 25 Gallon
Edit-
