craftsman pro torx screwdrivers
dave4512
Thx that is a good deal. I am going to try and order those even though I hate the website sometimes.
byoungblood
Berryville, VA
kc-steve
Kansas City
When you finish adding the T15, T20 and T25 at full price to round the set off, you are still money ahead buying the full set at once.
http://www.sears.com/craftsman-professional-7-pc-torx-screwdriver-set/p-00949302000P?prdNo=1&blockNo=1&blockType=G1
Thanks Hootbro. Since I didn't have any Craftsman "Professional" screwdrivers at all I bought this one last weekend and may add your recommendation as well . . . for my personal use.
http://www.sears.com/shc/s/p_10153_12605_00949020000P
Steve
pipsters
USA
Slickdeals people are idiots, they will buy anything if it's discounted
Hootbro
Delaware
Steve
You cannot go wrong with the Craftsman Professional drivers. I have about every model# of the current style they make and think they give any of the truck brand drivers a run for their money.
Only issue is that some of the sets have drivers that the stores do not carry as singles. So you may to swap out the whole set for one warranty exchange or the store can order the single.
gatewaysysop
Arizona
Definitely a :+1: on this. I own many drivers from the Craftsman pro line and I also have a modest set of Torx drivers. They've all worked flawlessly for me and are some of my favorites to use. For the money, they are probably the best bang for the buck that there is. :thumbup:
bimmerZ5
are the current red handle craftsman pro better than the old black handle ones?
Danglerb
SoCal
so functionality, durability, etc. are still the same?
I think roughly so, Craftsman quality goes up and down even in the same style. Both have a lifetime warranty, and seems to me if you are a heavy torx user then you are using bits or bit sockets.
Torx is also a more modern fastener, so Craftsman made even the basic drivers using modern processes (my guess) or at least meeting modern specifications. The pro is "supposed" to be better, and the tips are all dark finished, but some of the first batch of C Pro screwdrivers I bought were not hardened and twisted on the first screw I tried them on.
I kind of prefer the soft grip on the Pro, but don't dislike the old style and still use them.
One concern is that old style Craftsman might go to China before the Pro does.
billp603
NH
In my opinion no, not even close. I have a single P2 of the old black handle, black shaft "industrial" model (from the early 90's?) at home and we recently got a set of the new craftsman professional at work and the fit and finish of the handles seems poor. The end caps don't fit flush with the sides and the grip is just not comfortable for me.
anyheck
New Orleans
For reference, the full set of 6" driver part numbers if you want a full set is:
47180 T10
47181 T15
47182 T20
47212 T25
47213 T27
47214 T30
47171 T40 (8")
$32.72 when I added all of them.
Definitely the feature here is the long shafts compared to other brands.
csmitty
I've got the 7pc set. Had some issues with the first set. One of the smaller sized driver shaft was bent, and on another the tip coating was chipped off. Took em back and got one that looked a little better. They are nice and long though. I got a stubby set too on clearance, haven't even used those yet. But I tend to use inserts and sockets more anyways.
Danglerb
SoCal
Does Sears have Hex screwdrivers of this craftsman pro version?
Not unless they know how to hide them REALLY well. I tried a few searches and nothing in regular craftsman or pro lines with hex except for the bit driver handle (non ratcheting $27 bit driver handle).
In stores I recall them have Bondhaus or Wiha I think, some non Sears brand.
03protege
Louisiana
Didn't the Professional Screwdrivers use to come in black hard-plastic trays? Or did I make this up in my head? All the sets I see in stores now are in clear plastic packaging.
db130
Massachusetts
Thanks, ordered the T30 for store pickup. I have a vintage Proto set with yellow handles and a Gearwrench soft-grip set, this one will go into my "field duty" toolbag.
djb2
Redwood forests
..seems to me if you are a heavy torx user then you are using bits or bit sockets.
A long shaft is sometimes the only type that will fit into a recess. For me that seems .to be the rule -- I encounter deeply recessed Torx screws more often than exposed ones. Or the equivalent -- a punched access hole that won't fit a hex bit.
I suspect that there are a few Slickdealers that now own a T27 driver and have no clue that it fits nothing in their house.
volunteers
California
I dont' have T27, but I also wonder where this size of torx is used at?
djb2
Redwood forests
T27 heads are only used on things that you aren't supposed to turn or where the factory just wanted to mess with you.
It used to be only domestic (U.S. designed) headlight adjusters. Then in a few places where they should have used security screws. And Harley does it so that you have to buy new bolts when you use a T25.
Danglerb
SoCal
My first tool truck purchase was 25 years ago, Snapon 18" T15, want to guess what it was for? Nothing else would fit too.
obsessive
As djb2 wrote, T27 is used on Harley-Davidsons, but nowhere I'm aware of with restricted access. Since all the H-D fasteners have torque specs, bit sockets are necessary for final tightening. Spinner handles make work quick with bit sockets, of course.
csmitty
Stihl products almost exclusively use T27. Most things German will have plenty of torx. Had to get a long T27 bit socket for my saw.
