Snowblower hauler
gol4
Nebraska
Last snow storm I was struggling to load my snow blower. Since my pickup is a 4x4 it sits up pretty high so the ramps get kind of steep. I slipped and was lucky enough not to hurt myself or break the blower.
I decided there had to be a better way. I looked at cargo carriers but one with a ramp would be a couple hundred dollars. I decided to make my own. I headed to Lowes and after looking at the price of metal I decided I had better find some scrap. Next stop was the grocery store with the wife. Next door was a thrift store. I figured I would look around to see if they had a tread mill I could scrap. No tread mill but there it was, a bed frame priced at $6.98. It was angle iron, 2” x 1 ½ “on the long and 1 ½ X 1 ½” on the width. I figured it would work perfect.
I took a couple of measurements and broke out the $89 HF welder and got to work. Wheel base was 26” x 8” So cut and welded that up. I then welded 2 pieces into a 30” x 2” x 1 ½” square tube. Weld those together to form the carrier. A quick piece to hold the front lip of the blower was welded into place To form the 2”x2” tube to go in the receiver I had to use the smaller angle iron inside the larger pieces. For the hinge I used a piece of pipe welded to the receiver piece and some drilled metal pieces welded to the carrier. A ½” X 3” bolt is the pin. Some straps and a few holes to hold down the front. After a test run, it works but it is too hard to hold the blower and insert the pin. I need a catch. The answer for me was an old door catch I had sitting around. Some more drilling and cutting and welding and I have a safer way to haul my snow blower. I figure I am into it for less than $25 parts and materials. I did go thru a pound of wire and 3 disks. Drilling this stuff was the challenge. I did use all but a few inches of the bed frame. I just tilt the blower front up. Lift on the back and slide it into the front catch. Sit the wheels down then secure the front pin. Secure the strap away I go.
boiler7904
NW IN
Interesting. Might want to look into some magnetic trailer lights to put on the back of the blower while you're driving.
kbs2244
Have you driven behind it while someone else drives?
I would expect you will see a lot of up and down flexing.
I would add some cables from the platform up and over the tailgate and hooked to the cargo hold down points.
G
gol4
Nebraska
I do like the Idea of putting an extra brake light on the back of it. Will be easy to do. It does not obstruct the vehicles turn signal so not an issue there. I also plan on hanging a red flag just in case the law requires it
There is hardly any up and down flexing. I expected to see some of that as well. I can make it flex a bit from side to side by pulling on the handles. I have put all my weight on the handles and it feels pretty solid My only concern is not to take it down too steep of an incline as I've had my hitch hit the dirt once when off road. I won't see that problem where I will be using it.
I think I will add safety chains as well. If the pivot point would break then I could drop it in traffic. I should treat it more like a trailer then a cargo carrier.
Thats the beauty of this forum, You can always get some great ideas.
24X26
Excellent idea and design but that thing scares the **** outta me.
Not because of the HF welder you used (Flux core I'm assuming?).
Bedframes are made out of the baloney of the metal world.
Next time you have some bed frame angle iron, drill into it at various places.
You will see that some places it drills like butter while other places it will dull
the bit.
Not trying to rain on your parade or anything because I really do think it is a great design.
Bed frame is good for non critical projects. I've used it a ton of times.
Something going down the road though... not so good.
theoldwizard1
SE MI
... My only concern is not to take it (up or) down too steep of an incline ...
Yep, have to watch that !
Not trying to be critical of your skills, but check your welds and the welds on the hitch regularly ! That is a big load on a bigger moment arm !
str8axle55
Ma
Pretty neat idea. I`m sure if you find the need you can improve on the design. Looks good for short trips, but I would want to add a safety of somekind, so it doesn`t fall off in traffic, if something fails.
ilovevocs
Toledo, Ohio
Nice setup. I have been thinking if doing something similar for my pressure washer. Hope it serves you well!
PCO6
Newmarket, Ontario
gol4 - That's a pretty good idea. Based on your avatar, your wife and girlfriend seem to be impressed!
:lol:
I have rack & ramp hitch insert that's designed for a motorized scooter for the disabled. It works well for lawnmowers, snowblowers, etc. but it's bulky and fairly heavy. I might replace it with something like you have built.
Big-Foot
Midlothian, TX
Nice Job!
I used a Beaver Tail and ramps for mine back when I needed to transport it.
License plates are obscured when towing a trailer too so what do the cops do then? Nothing around here.. Now take off your front license plate or have it bent-up or dirty and they will pull you over.. Exception seems to be for dirty plates in the winter though..
Burtonrider10022
Chicago, IL
That carrier looks great! As kbs suggested, though, if it were mine I would also do this. It will only take you a matter of a minute to hook up a ratchet strap or two and use the cargo hooks in the bed.
The straps would not harm your paint going over the tailgate, it will only take a minute, and I'm sure you have some ratchet straps lying around - so really, you have nothing to lose by adding a little bit of a precaution.
How heavy is the snowblower?
G
gol4
Nebraska
My blower is only around 215 pounds. I am also only using this on city streets. My rental that I have to clear is about 1.5 miles away.
I now have a safety chain that I am wrapping around the auger and hooking to the receiver so even if it was to fail it would get dragged behind the vehicle and not go into traffic.
I would agree that additional straps would not hurt and add as an additional safety measure.
You can never bee too safe.
Burtonrider10022
Chicago, IL
Good to hear, and I can now say, awesome job on that thing!
