Quite a bit more work accomplished on the garage.
The siding is now finished… Looks really nice!
All of the gutters and flashing have been installed and with the exception of a few details (garage doors, exterior lights, and electrical fixtures) the outside is more or less complete.
There is still a lot of work to do on the interior of the garage though. The HVAC subs were in to run the lines for the furnace and air conditioner. The air conditioner was pretty straight forward as far as installation. We had to replace the undersize unit for the house so it seemed like a good idea to place both a/c units at the rear of the garage and away from the house/pool area. No real problems there… Just the need to run the line from the old house unit to the new location (about 30 feet away). The new house unit was installed while the garage unit will be installed in a few weeks.
The one area of compromise in this garage so far is the furnace location.
I wanted to keep everything off of the floor to maximize my floor space. My first thought was to put it above the ceiling on the trusses, but there were some issues regarding code as well as how to service it once it was up there. The left (as you’re facing the garage) side of the garage seemed to be the best location except that I plan to put four post lifts there in the future to increase car storage capacity. The front was out due to the garage doors. I wanted to use as much of the back wall for full height storage cabinets so that ruled out most of that area… This left me the right side. This is the area by the lift and I was concerned that it might interfere with the cars, but after taking some measurements, it became clear that I had sufficient room (As long as I never lift a car more than ten feet wide). This location also leaves the unit clear for service work when necessary.
I gave this one a lot of thought and this appears to be the best solution. You can make a case for the back wall (I did), but in the end, the solution that I chose should work just fine.
The ductwork for the heat and a/c was put in place.
Most of the electric service was run at this time too. I put an outlet every six feet which from past experience should be sufficient. I ran a 220 line into the storage area for the compressor and another at the front of the right side for a welder. All the drops for the lights and garage door openers were done and a “special” outlet high on the far wall for a neon sign I’ve had for many years, but never had a place to hang.
Not a whole lot left to go at this point. Insulation, drywall and painting, finish HVAC, finish electric, complete the lift installation, and finally put down the epoxy floor. With a little bit of luck, I might be able to start moving my cars and parts in by the end of the month.
Regards,
Stan
