Recently purchased a newly renovated home. All the electrical is new, from the pole on the street, to the meter, panel, and branch wiring.
There is a crawlspace/cellar area under the home. Sometime in the 40's it was dug out so there is about 500 SF of standing height space down there, split between three "rooms" created by foundation walls.
There is a single GFI outlet on a dedicated 20A circuit down there. There is a single switched light fixture, which is on the same circuit as as the lighting and outlets from the formal living room above it and the outdoor porch lighting.
I need more light down there. It's not really a workshop, just storage, so the single GFI outlet is probably sufficient for what I envision being done down there. Something like 3-5 single bulb fixtures with cages on them.
I'm hesitant to add the new lighting to the existing lighting circuit, as it already feeds the 5 outlets, lighted ceiling fan, a porch sconce, and a motion light.
I was contemplating just adding the new lights (and rewiring the existing one) onto the load side of the existing dedicated GFI circuit, which means they'd go dark should the GFI trip. It sounds like this does not violate any codes, but is poor practice as it would leave the area blacked out if you were down there using a tool and tripped the breaker or GFI.
Adding a whole new dedicated lighting circuit down there is possible, as there is plenty of space in the panel for a new breaker, and the wiring runs would be reasonable. But, I'm a wiring newbie and it's a more involved project for my first real electrical experience.
Thoughts or suggestions on how to approach this are appreciated. Also, can the new branch wiring be tucked and stapled out of the way, or does it need to be run in conduit of some type?
