Off-Peak Storage heaters
Ramper
Southern MN
Is anyone familar with the use of off-peak thermal storage units? The use electric at night to heater ceramic bricks and then release the heat during the day. There is a 3 Kw and a 2Kw unit listed in a local CL. The off-peak electric is $0.06 versus $0.11.
blind
KY
No experience with one but my electric company gives rebates for them if replacing other forms of electric heat.
4everRS
MN
Our electric co-op requires you to have another fuel source for this. Otherwise known as "dual-fuel". We use an off-peak plenum heater in the duct above the furnace, and when they shut us off, the propane furnace automatically kicks in. Out rates are 4.2/8.4 per Kw/h. I wish I could speak to the stored heat system. Sounds good if its not to expensive up front.
Stuart in MN
Minneapolis
I used to work for a company that built off peak storage heaters (they've been out of business for a long time now.) Most of them use some type of brick to store the heat, ours used rock but it was the same principle. Typically they are metered separately from the rest of the house, so the electric utility can keep track of when the heater is on and charge accordingly.
They can work pretty well, although if you have extremely cold weather they may not have enough heat stored up from the off-peak period to last through the day, and then they have to run the heating elements during the peak period which will cost you more money.
Another thing to consider, if you're thinking about using it in your garage, is you don't want to use spray paint or other aerosols around them - the particles in the air will get drawn across the heat storage bricks and burn into them, making a big stink.
It's been long enough I don't know the players in the heat storage field anymore, the only company I can think of still building them is Steffes. http://www.steffes.com/
tdkkart
Eastern Iowa
All of us that have radiant floor heat can do this, bump the heat up during off peak and let it coast during peak hours. Concrete slabs store a lot of heat.
