70NOVA
Need a new set of drill bits that will last but don't want to break the bank. They will be used mainly on 1/8" or thinner sheet metal. Any suggestions?
I have been using drill bits from HF for at least 25 years, and while they
aren't the industrial "best" they are far from the worst either. Get the
regular black bits in a tin case. 1/8" bits are available in a bulk pack.
If you don't force the bits, or bend them as you are drilling, they will
do the job you want to do. I use the fractional, numbered and Silver
Demiing that go up to 1". Drilled a lot of steel, alum, brass, and wood
for a fraction of the cost. When one breaks, and I need that size, I
scoot to the local hardware store for a single bit out of the display.
I keep packs of 1/8" and 1/4" in stock, seems I use a lot of those.
Resharpening: after a while you get a good feel for it, especially if
you do it freehand enough on the bench grinder.
Uncle Bob
My experience pretty much agrees with this. They are ok, but they aren't for more than soft wood. Caught a good deal on some Dewalt pilot point cobalts on amazon recenty, they go pretty good through thin sheet, haven't put them through anything difficult though. Just tested with some scrap.HF titanium nitride or Cobalt drill bits have been excellent for use in my garage machine shop. Their high speed steel drill bits proved to be pretty worthless.
I don't use mine all the time but I got a set of each and am seeing the same performance with both.My Hf unibits keep up with the Irwin's
