inane2
Good morning all.
Just ordered a Challenger E10 two post lift, 10k. It is set up for right at 12 feet tall.
I can order the 2 foot extension kit to put me right at 14'. This will get the cut-off bar up a little higher.
I'm 6'2" tall and will be working on full size half-ton trucks (F150, 1500's) and full size SUV's (Expeditions, Tahoes). This is not a commercial application by any means, just a back yard garage.
Do you guys anticipate any of these vehicles hitting the cut-off bar or should I go for the two foot extension kit? I realize my rise height is limited but I'd like to be able to work comfortably under the vehicles.
Also, on my 14' ceiling ...... where my lift will be installed, it will cross two trusses (6' OC). The bottom chord of my trusses are 2x8. Measured from concrete up to the bottom and got 13' 11'.
So technically, even if I need the 2 foot extension, I don't think I can make it work without notching two trusses slightly. What are your thoughts on doing so? The location of any possible notches would be 14-15' away from the inside header at the posts.
Thanks for any info / advice. I've seen there are several lift owners on here!
