sprackydoo
Hey, someone showed me a tool I absolutely need (really I do
Ayways, it's for punching holes through grommets. Like if you wanted to add an aftermarket wire to go through the firewall through an empty grommet to the batt.
The tool has a handle like a screwdriver and a tube that goes all the way through it and the business end is cut on an angle. The tube goes all the way through the handle so you can feed wire through the handle punch a hole slide the wire through and remove tool to make a nice tight fit.
He said he got it from a Snap-On truck (but tool isn't Snap-On) and he hasn't seen one before or after that. Anyone know where to get one or even have the name of it?
-Thanks
)Ayways, it's for punching holes through grommets. Like if you wanted to add an aftermarket wire to go through the firewall through an empty grommet to the batt.
-Thanks
Exactly what I was looking for, thanks.
