Good Brand 1/2 Pin Punch
MechanicforLife
Hey guys whats going on I need some advice, Idont have any Pin Punches and I need to drive out some rivets from a chevy upper control arm. Ill be doing the ubj Any good brands out there? I seen the SK 1/2 Pin Punch for $33 is there something out there a little bit less exspensive thats decent?
________
GL1500A
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
Semi hijack:
I've talked with both my father, and old timers (70+) and they have always talked about grinding their own, out of things like old axles. Anyone still do this? What are good sources of metal now?
Brad54
I've driven plenty of rivets out with Craftsman pin punches and alignment drifts.
I don't think I have one that big (1/2-inch), but I've driven out the rivets for rear leaf spring hangers on two Dodge Dakotas, and factory ball joint rivets on several Chevy control arms with them.
Over the years I've put together quite an assortment of alignment tools and chisels, based off a craftsman set with several of each.
Inexpensive, they get the job done, and they're easy to buy 'cuz you don't need to track down a truck.
Easy to warranty, too--but I always dress the ends of mine every time I use them, so I've not had any break or require warranty.
-Brad
wantedabiggergarage
Member Emeritus
-Brad
Home use, I haven't had any problems with the Craftsman. But helping a friend with a commercial mixer, I have. Because of that job, I figure I will have to make some of my own (considered some old rebar I was offered).
Uncle Buck
Kansas
Enderes, Mayhew, Starrett, Proto, the truck brands, and Crafty have a bit of all, no issues with any of them.
Vinko
Los Angeles
I've bought Enderes from the local hardware store. For home. Haven't used those a whole lot. Mainly just for carpentry. To drive finishing nails in. Knocked out a couple of broken bolts, etc.
MechanicforLife
Brad54,
Thanks yeah it wasnt that big of a punch I needed I mistook that size with the size drill bit I needed to clean up the upper control arm, I ended up getting that $20 craftsman Pin punch set thanks. Thanks everyone too
________
XL75
eschoendorff
So you've had bad luck with Enderes stuff? How so?
I ask because I've been tempted to buy a couple things lately.
Bad luck???? How did you get that I have had bad luck with them? I simply forgot about the Enderes brand. I wouldn't hesitate to give them a try.
Sorry... just reread your post. BTW, the Enderes seem to be pretty cost effective around here. I would definitely give them a try if I were in the market...
