The simple and cheap essentials
Eric_C
I've been working on cars for about 7 years now and have slowly built up my garage.
I now have a hoist, big tool box, big air compressor, etc...but there is always something more and I tell people you always go back to the very simple things.
I've helped a few people get started on working on their cars and they always look at the stack of tools and think its too much to invest in.
The big investment isn't in getting the tools to do the work, its in getting the one special socket to do one job...that just happens to be in a big set and you figure well I'll just buy the whole set :)
I figured this might be a good sticky of the things that are absolute must haves to save yourself time and trouble.
Most of the times they are not the big dollar items, but the cheap simple stuff that make life way easier.
On my list:
2 24" breaker bars...why 2 because when you buy one and wonder when you'll need 2, you'll need two.
2 6' sections of steel pipe to fit over breaker bars
2 3' sections of steel pipe to fit over breaker bars/wrenches
Pry bars, always need a pry bar
Lights...good lighting beats all else. Lighting makes the worlds most difficult job easy. You want blinding light you can shine into area's. I have an assortment of lights including the great $3.99 Home Depot 9 LED flashlight. Its tiny, very bright and cheap enough you don't care of you glue/tap stuff to it. I have a few of them, some with magnets glued on for placing exactly where I need it.
Cheaply Chinese wrenches...good for bending and cutting to make custom tools. A local place sells them from .99 to 2.99 upto 19mm. Yes they are junk and I doubt they would last. I'd never use them everyday but great for torching and cutting to make speciality tools. When you look at a bolt and think that it would be so much easier if the wrench was bent...well here you don't have to cut up and bend your pricier stuff. I have a few spares of each on hand.
If your doing automotive work, especially suspension get a few of the cheap Harbor Freight bottle jacks. They go from 12.99 to 19.99. Again I don't know if I'd lift a car with them but they are great for an extra set of hands. Doing suspension work on the ground is made much easier when you can place a bottle jack under something, especially something under tension and move it up and down easily.
15' ft of single strand coated electrical wire. Its like .40 a foot at Home Depot. Get some 14 gauge single strand. Its very stiff and coated. Great for tying things out of the way. You never want bushings, brake lines, etc to sit stressed when parts are hanging, great for tying stuff up. I keep a drawer full of it and you can cut it up and re-use it. Good for holding about 30lbs, more than enough in most cases.
Fatigue mats if your standing much. Not really something everyone has the need for but after spending more time standing working on the car rather than sitting or bending over they would be very helpfu.
Everytime I do a big job I keep adding to this list. I just did my clutch in our Audi A6 Quattro...thats when I realized I needed 2 6' steel pipes, not 1, and 2 breaker bars, not 1. When I put poly bushings in all the suspension components in my Corvette last summer I picked up several bottle jacks that made moving everything into place a one person job. I cut apart and bent a bunch of wrenches to take the exhaust off the turbo's on the Audi.
It would have been the difference between sweating and swearing and getting the job done easily.
I use those tools, especially for suspension work, more than anything.
I'd be interested to hear others suggestions. Tips and tricks always help. A good one I learned today was my fly wheel needed to be torqued and then + 180 degree's. Well no room to swing a big pipe 180, or even 90...yes I could do 45 and how do I know where its at when you can't make a sweep from 12 to 3, 3 to 6, etc.
I put a small wratchet on one of the bolts which I could swing 180 degree's. I knew I had at least of 45 degree's between the subframe. I put it at 12 o clock, then moved the wratchet in its reverse direction to 3 o clock. I counted the clicks it made. then I put the wratchet down at an angle where my breaker would fit and counted it 10 clicks. Made a mark on the subframe and then knew if I took my breaker and went from the edge of the subframe to that mark that was 45 degree's.
Thats when I realized, somewhere after the 20th time moving the breaker bar that another 6' pipe would be pretty nice. 8 bolts, 45 degree's at a time x 4.
Any other suggestions?
chammyman
Glasgow, Scotland
breakers bars agreed, don't go comfort handle though!
Pry bars, I went for years without using them, I used screwdrivers, chisels or bits of pipe. But when you get a decent set of pry bars it makes a world of difference. I would pick a pry bar over a heel type bar.
Lights, led handlamps never last, they get dropped covered in oil etc etc, maybe not so much if your a weekend warrior right enough. The LED miner style head torches are great.
Spanners agreed although here we just tend to abuse imperial ones as nothings imperial here anymore. So rusty nuts etc get a size between 2 sizes hammered on. But cheap spanners are great if you need to crank them to fit in behind something or even chop up to make them short enough.
bottle jacks I have found last longer than trolley jacks, they are more reliable.
I use cable ties, or zip ties or whatever you folk call them over there. Get a bag of 100 for a couple of £. I have wire for testing or shorting things out as needed.
Cheap sockets into which you can weld in bolts/nuts for certain jobs like the caps on VW gearboxes.
If you can get oxy/acetelene, a small blowtorch can help but the big stuff makes so many things easy, from burning out bushes, bending spanners, rods etc, getting nuts and bolts out and so on.
One of the oil pump things for taking oil out of sumps etc, you know a bottle and a hand pump and you stick the tube down the dipstick. They are really handy especially if you get more than one, taking out brake fluid, trans oil, diff oil, oil out of headbolt holes and blah blah
Tipex the viable altenrative to enging locking tools.
E
Eric_C
Yeah for what I do the LED's have worked fine. I just buy the small ones and tape/glue magnets to them. You can stick them whereever you want and point them where you want without getting in the way.
Welder is next...VW/Audi must use butter in some of their fastners like the driveshaft bolts. On a few of them it would have been easy to weld in a cheap hex and remove the bolt.
Tipex? Never heard of it before, what is it?
logical
Northern fringe of the Motor City Suburbs
This may or may not belong here...I spend a lot of nights in hotels here and overseas, and am in ant out of factories quite a bit.
I bring home the shower caps to slip over electrical areas when washing engines or motorcycles, or just to slip over any open area you want to keep debris out of. many japanese hotels have these neatly packaged compressed body sponges that make great spill containment absorbers. The cheap ear plugs from factories get used to plug the dripping ends of detached fluid lines of all sorts or keeping debris out of threaded holes. Now if I could just find a use for 150 little bottles of shampoo.
Jay H 237
Torrington, CT
Rags!
Any old clothes, towels, ect I have go in a box in the garage. The larger items are cut up. Now when I need a rag or towel for something I have plenty.:thumbup:
I've gone over other people's garages to help them and sometimes you can't find a rag or even a paper towel when you need one.
musgofasta
Corona CA
My LED headlight. Yes you'll look lame, but it's SOO nice.
Box of Latex gloves when I work with nasty stuff or garage fluids.
Box of wood pencils, because you'll leave them everywhere
+1 on the Zip ties - Gotta have all sizes ready.
Gojo Hand-cleaner for when you're done. Don't want to touch Mrs. with these paws!
Bevis
Moore Haven, Florida
for hanging things, I welded two u bolts together. one end hangs in a frame hole and the other end i can hang the brake caliper on, etc.
ovilla
Plainfield, IL
Latex gloves - I buy them in the 100 ct box. Great for when you need to answer the phone or go start the car after an oil change.
Safety goggles (not glasses) - Stanley sells a pair that you use for drywalling and are made with a coating that prevents them from fogging up. Good ski googles also have the anti-fog built in to them.
Coveralls - I have a light weight (summer) one and a thicker one for winter use.
Magnetic work light (with a flourescent bulb). Better than a light with just a hook.
Wire brush that can be chucked into a drill - Trully awesome for removing dirt/rust from anything.
Saran wrap - I often take the laptop out to the garage for car research or to view parts diagrams. Anyway, I wrap the whole thing in saran wrap so I can type on the key board with dirty hands. I also use it to wrap electrical parts I don't want getting wet during engine cleaning.
Mechanics Stethescope - Great for finding fuel injectors that aren't clicking, exhaust leaks, and valves that need adjustment.
Large 16 quart oil drain pan.
Magnetic Tip tool retrieval tool - You'll find endless uses for this thing.
Amp Meter - Extremely helpful for electrical issues.
Flare wrenches - Great for brake lines or anything else you want an absolute grip on. They're really the next best thing to a socket for times when you just can't use a socket on some thing.
MAPP gas bottle with striker nozzle tip - Not just for plumbing use. I use it all the time to apply heat/persuasion to rusted on bolts.
IR2135 Impact gun - No need for breaker bars or pipes to go over the breaker bars.
Fuel shut off clamps - Come in super handy when changing out fuel filters.
Fish Aquarium tubing - It fits over almost all brake bleeder ******* and will help you make your own brake bleeding reservoir out of any 2-liter plastic bottle.
PB Blaster and CRC Freeze Off - The best rust removal liquids ever. You can even use CRC Feeze off to freeze a master lock (just hold the can upside down as you spray the lock) and then watch it break into a ton of little pieces with a good whack from a hammer - Yes, it gets that cold!
3/8" and 1/2" drill adapter - This will help you put any socket on your cordless or corded drill.
Seafoam - Great for ANY engine. I use it all the time to clean fuel injectors on cars and even add it to my lawnmower's gas to treat clogs in carbs.
3 lb (or 5 lb) mini sledge hammer - Great for removing rusted on rotors.
Tub of anti-seize - Use on all bolts and especially on the back of rotors before placing them on hubs.
Torque wrenches - I've got the little one with the sliding scale and the big one that clicks to tell you when you're done tightening something. These will make sure you never over tighten anything.
3/8 to 1/2 and 1/2 to 3/8 adapters - Will allow you to use any 3/8" or 1/2" socket with any ratchet. Some times you'll appreciate being able to use a 1/2" ratchet on a small 3/8" socket.
rsanter
visalia ca
pull down reels for the air, 110v power and drop light.
they will allways be right there for you to reach for
folding table
cant imagine how often you need just a little more space to lay stuff out
bob
JohnZ
Washington, Michigan
"Project Center" box on wheels - I keep my tune-up tools/instruments and a set of standard frequently-used tools in/on it and take it to the car I'm working on - saves walking back and forth to the bench area.
jcp907
Seminole County, FL.
The first thing that comes to mind that hasn't been mentioned is at least two fire extinguishers, one on each side of the garage.
Line wrenches for brake/transmission lines.
Charles (in GA)
50 mi south of Atlanta
Excellent suggestion, but fire extinguishers are no good if you cannot find them in a hurry, and it might not be you, but rather a buddy who is unfamiliar with the shop, who needs to grab it. Get some signs to install high on the wall above the fire extinguishers to show their location. Take a lesson from your workplace in safety related items and signage, there is a reason they have it at work, and the same reasons you should have it at home.
http://www.grainger.com/Grainger/items/1NL60
Charles
IH82BL8
Bowie, Md
Bench vise and a set of dental picks...you'll use the latter more often than you would expect.
thomask
Sunshine State
:)John Z great idea.
Bought the exact same rolling cabinet when building addition on far end of house.
Tools and hardware always in reach and organized.
You are right it saved me miles of walking back for tools/hardware, helped keep job site organized, and less stress searching for misplaced tools.
Liked it so much after I finished the project I bought another one.::thumbup:
ddawg16
S. California
Chunk of carpet to lay on....I have a creaper....but if I'm stabing the transfer case into my jeep, the creaper is more trouble than help....it tends to roll me away from where I want to be...carpet (or old bathroom rug) is comfortable and keeps me planted where I want to be when I'm yanking on something...
Baggies - I like the 1 qt size....keep a sharpie near by and it's easy to keep track of parts while you pull them off....really great when the project takes 2 years.....like, who remembers where a nut goes after 6 months.
Loooonnnnggggg extensions for the 3/8" drive set.
Digital Camera to take progress pics.....great way to share projects with friends and helps remember where parts go.
Cordless phone - So you can order beer from the wife or tell her to call 911 because you droped the car on your leg.:beer:
Razor blades - Like the box cutter type.....
Cleaning brushes - so many uses....HF sells a box of 50 for like $2.
Electrical tape - To cover up the "Oh Shits"
e-tek
Saskatoon, SK
Some great suggestions here guys.
Ovilla - if I read that right, you're the only guy I know who puts gloves ON when your hands are dirty!
As for things to lay on/stand on, I bought a couple packs of those "play" foam/rubber mats that fit togther like puzzle peices. They come in packs of four for 20bucks. One or two together are great for laying on out in the driveway, or for standing on when you're working on the car or at the bench. Also good for putting bumpers or body panels on.
trackwelder
n.y
A good first aid kit with plenty of bandaids, ointments, etc and a tube of crazy glue for deep cuts. Plenty of drinks and snacks to keep you going along with a nice radio and lots of cd's.
Bo Heck
Radio is good, but I prefer to have it hooked to an MP3 player that's set on random:thumbup:
Coach James
Sandhills of North Carolina
Big sheet of cardboard to lay on when changing oil. Keeps the rocks out of my back and soaks up oil that would drip onto the ground. When it gets old, toss it in the recycling bin and find a new piece.
Metal coat hanger to hang up parts after painting or brake calipers so the lines aren't stressed.
Romanova
Cypress, TX
When I did the clutch on a buddies Eclipse, I used a large sturdy piece of cardboard to punch all the bolts through. That way, I could label them on the cardboard and draw simple diagrams if necessary. Worked very well.
I keep the large plastic jugs from my laundry soap to use as used oil containers... as my Scion takes 4 quarts and I buy 5 quart jugs at WalMart. Works pretty well.
neitzel
Boise, ID
I have got to agree on the extensions. The long ones are real knuckle savers.
Also have a good variety of sizes so they can be mixed and matched if needed to get you just far enough away, but not to far if there is clearance issues behind your ratchet.
InPrimer
lake Havasu AZ
couple of trivial stuff I use, a Sharpie, Metalic Silver, great for marking timing light and TDC, also as witness marks , on our pool filter the handle gets cranked to the right or left, easy to put it back to the proper position using a witness mark, Q tips, buy them at the $$ dollar store, great for cleaning inside small areas,also to keep out of the sh**t with the wife, 5 gal bucket with simple green, if rags are not too contaminated with grease I soak them for a few days and then sneak them into the washer when she goes to get her hair done, haven't been caught yet!!
ket-tek
I second taking safety tips from commercial applications.. Multiple fire extinguisers w/ signs, eye wash attatchment to your slop sink faucet, first-aid kits on the wall with signs, and an automatic emergency light unit. I work in the garage late at night alot, and if the power were to go out it's pitch black in there.
nonhog
Arizona (Tucson)
An old truck mirror for those times when stuff gets in your eye. A big ol
truck mirror mounted to the wall at eye height not a little hand held car mirror.
boiler7904
NW IN
Dry erase board and various colored markers.
I keep a list of things I need to pick up the next time I go shopping on the left side of the board and a list of projects that need to be done on the right.
Mattlt
MN
Ditto!
I also write maintenance info on one corner of mine (oil changes, etc)
SportFury59
Wisconsin - Wausau Area
Sometimes if the 3/8" or 1/2" extensions are too short or too long for a specific job, have some 3/8" and 1/2" square stock on hand and make/cut your own the right length for the job. Had to replace a transmission on my '59 Plymouth awhile back and this really came in handy.
Ditto on using cheap wrenches to cut or bend them to fit specific jobs. Kinda funny,.... a year or two after you used them that one time you can't remember what you used them on. (anyway I can't)
Rte66Charlie
Ozark Mountains
I noticed latex gloves mentioned a few times - I prefer the nitrile gloves (you usually find them in blue) - they are a LOT TOUGHER!
Also on the "you'll-be-amazed-how-much-you-use-them" list..........Q-tips! Store them in a little jar on your workbench where you can get to them and you'll find you are restocking the jar on a regular basis!
metal1313
clinton NJ
little things that make my life easier; nitrile gloves, safety glasses, goggle, and face shield . wire brush, the cheap little paint brushes with metal handles, chip brushes, iron worker's wrench, use it to line up a part, slip bolt in, turn it around and hold the bolt/nut. 110v flux welder. use it to weld a nut to broken bolts, leave it off a third or so and fill the void with weld, the heat ususally brakes it lose
rieferman
Collegeville PA (30 min west of Philly)
good call on the mirror above, that's now on my list
One of my favorite buys ever was about $1.99 at the depot. Just a retractable holder for my carpenters pencil. Similar to the ones you'd use golfing. I just clip it onto a pocket or sleeve or wherever and the pencil magically follows me around all day. Good pencil.
IH82BL8
Bowie, Md
I mounted 3 cabinets over my work bench.
Falcon67
Merkel, TX
Of the items listed, I use a lot of nitril gloves, q-tips and lots mentioned.
I tinker and maintain two race cars and one drawer in the box is for "specialty" tools. Stuff like pipe joins modified to fit over and drive home seals or for use as bearing press tools, lots of bolts with the heads cut off and screwdriver slots cut in the ends - used for guiding home intakes, transmissions, headers, motor mounts, you name it. Bent and twisted wrenches and screwdrivers for odd-ball jobs - you can tell that someone has spent time messing with engine headers a lot by counting the weird looking 7/16" wrenches in their box LOL.
I did a lot of work on my hot rod in the 70s with nothing more than a couple of small hand carry Craftsman flip top tool boxes. But it's nice to have lots of stuff to fall back on. It just takes time to accumulate. I'd also tell young 'uns - if it's a regular tool, buy the best you can afford and take care of them because they will serve you for a very long time. My 3/8 and 1/2 socket sets were given to me by my grandmother for my birthday - in about 1970. Got to pick them out of the Sears catalog.
