signcrafter
- Joined
- May 9, 2012
- Messages
- 12,359
I'm a believer in changing fluids, it's cheap and usually pretty easy to do. I do brake fluid, coolant, and trans fluid at regular intervals. But for whatever reason I've never changed the power steering fluid unless I replace a part. Want to add a power steering fluid change to my routine. Been watching some youtube videos on it and seems it's pretty common to get problems from air in the system.
What is the easiest way to get do a PS fluid exchange at home? Would a mityvac extractor like this, http://www.tooltopia.com/mityvac-7400.aspx or it's air powered version work to empty the resovior? Trying to keep the mess to a minimum and some can be a pain to just undo the hose. Or would the filter screen prevent the sucking out of the fluid? Any other ideas on getting as much fluid out of the system so I can add new?
For the bleeding of the PS system it seems like some are fine just turning lock to lock and some systems have issues with air. In a couple videos I watched it shows using a mityvac hand pump and an adapter like this, http://www.etoolcart.com/power-steering-evac-adapter-mty-mva660.aspx. I like to have the tools to take care of any issue that might come up when doing something. Don't really want to change the fluid and find I have an issue bleeding it and then have to order the tools to fix it. So if there's a chance I will need these to bleed the system I would like to have them on hand. If I don't need them then it was cheap insurance!
So what do I need to change the power steering fluid? I work on mine and my families vehicles so have some GM, Chrysler, Ford, and Honda if that matters.
