Commonly used sizes for hex and torx sockets
ToolGlutton
Washington, DC
Hex keys and torx bits could do most of the easy job.
When it requires strength, we want to use hex or torx sockets. So what's the most commonly used sizes for hex and torx sockets?
I overheard in this forum that
1) someone owns all types of 6-mm hex bit socket (long, short, medium). I guess 6-mm must be a commonly used one.
2) 3/8 hex socket is commonly used for brake calipers.
3) T55, T60 are commonly used for GM brake calipers.
What else?
billymade
New Mexico
00947744000
Lisle Brake Caliper Socket Set
Sears item# 00947744000 Mfr. model# 12550 $7.99
http://www.sears.com/shc/s/p_10153_12605_00947744000P
Lisle brake Caliper socket set for servicing disc brakes. 8mm hex bit for GM applications, 3/8 in. hex bit for GM applications and 1/4 in. hex bits for Ford.
T
ToolGlutton
Washington, DC
I do not know why they did not mention T55. See below:
SK 7 Pc Disc Brake Caliper Set
Sears item# 00999503000 Mfr. model# 84227
"7 piece set contains the most popular hex and TORX sizes for servicing disc brake calipers on domestic vehicles (except Chrysler). Contains:1/4", 5/16", 3/8", 8mm Hex Bit Sockets; T40, T45, T50 TORX Bit Sockets Packaged on a rail.
Set does not contain a T60 TORX bit needed for some late model GM vehicles."
Diesel-Mech
Kansas
I use T50 and T27 torx quite often while working on horton fan hubs.
Although most of the rebuild kits come with a T50.
eschoendorff
What else?
It really depends on what you are working on. If you are working on GM cars or trucks, you'll get one answer. Audis and VWs, you get something different. And that is just for automotive stuff. If, for instance, you even need to work on Stihl power equipment, you'll need some high quality T-27 torx.
You might get better answers if you make your query more specific....
wolf_from_wv
WV
3/16 for AR15 handle?
1/8 for tub faucet
3/8 for S10 caliper bolts
9mm for Ford Escape calipers?
Tonyuk
Scotland
In my service cart i keep a set going from T10-40 and hex in 4-10mm Larger sizes of each in the tool box.
It all depends on what brand of cars your working on, for example with a VW you'll also need spline and triple square, modern BMW have a lot of female torx etc..
I would just get a good quality set of each, undoubtedly you'll run into non-standard fittings that other techs or the owner has put on if the original was damaged or lost.
matt01073
western mass
My thought would be if you dont know what sizes are common , then you probably dont use any and dont need them . What is common for one person may never be used by the next guy.
Jure
Croatia
t40 and t45 for drain plugs...opel (GM) oil drain plugs are pretty much all t45
wolf_from_wv
WV
T6 (or so) for knife clips
T8 (or so) for disassembling computer hard drives
TT15 for coffee pot
T20 or 25 for deck screws
T20(?) for ford Focus door panels
T15(?) for '85 S10 dash screws
maydaymike
My 2014 Harley has a ton of T27 on the engine. I had to buy a socket, 'cause the set I had skipped that size.
R_einan
Eastern WA
Harley compensator bolts are now a t70, big SOB... you also need a 12mm long hex socket and a 19mm hex to disassemble the forks on '14 and newer touring models.
skruft
I have had to use a T55 on very tight bolts quite a bit and feel that the common ones with 3/8 drive put too much strain on that drive - I recommend one with 1/2.
jgromada
Maryland (between DC & Balt)
I think the person who mentioned that you need to specify what you plan to work on is SPOT ON!
No one mentioned Triple-Square, but that is mandatory for VW and probably others.
Real_PhillBert
Fargo, ND
T-20 is Ford Focus door panels (already mentioned)
T-30 is Ford Focus undertray
T-47 is Ford Focus seat bolts
You can probably guess what I drive ;)
Spacey_G
Yeah no kidding. My most commonly used sizes are .028, .035, .050, T5, T6, and T8. No way I'm using bit sockets though!
wafrederick
Holton,Mi
T60 on the older GM W bodied cars,front brake caliper bracket bolts
T50 torx plus,GM 4l60e bellhousing bolts into the case
5mm hex,timing cover bolts in the Subaru H6 engines
MushCreek
Upstate South Carolina
I can't imagine being without full sets. I have T7 through at least T50, 1.5mm through 14mm, and .035 through 5/8". In my trade working on plastic injection molds, everything is socket head cap screws, and insertable carbide tooling is mostly Torx. Then I come home and tinker with cars.
