tile requirements
toddcalo
michigan
Im considering putting tile in a garage - workshop. but I have some ??
A couple things Im being told locally is that I would want to put a liquid isolation rubber membrane between tile and floor, also to use porcelain tile where the color goes completely through. use epoxy grout and flexible thinset, also porcelain is supposed to be better for heat and no heat in a cold climate. I would like to keep this affordable and if I do all this stuff its going to get real pricey. Is this really the only proper way to do this ?
slickgt1
Re: tile requiremnts
You were told some strange stuff.
No membrane between tiles and concrete. Waste of money. Plus the liquid membrane costs a ton. Like a **** ton. Don't do it.
Porcelain through body tile is just that. It is a bit stronger than ceramic, and if you do manage to chip it, it will be same color underneath. That being said, there are a ton of people that have done ceramic, in a working garage, and have no issues with it at all.
You can use any grout, just seal it if you will be working on cars, and have oil spills. I did Epoxy because I didn't want any maintenance at all.
I also used the cheapest thinset there was in the store. First few bags were gray thinset, some were white, I wasn't picky. Not like I will see it. Consider getting a kerabond liquid thinset additive. Will make your thinset tough as hell.
Look for tiles that are PEI IV or PEI V, those would be the ones you want for your garage and climate. Coeficient of friction above .55 would be about the same traction as concrete. That's it. Don't go crazy putting down all the fancy **** people try to push on you. Trust me, it will be tougher than most any floor you will put down. Look at my sig links if you still have doubts.
T
toddcalo
michigan
Can you buy regular grout that is not epoxy that dosent require sealing?
Dakota00
Woodbridge, Ontario
Regular grout doesn't require sealing. But I do recommend sealing light and medium color tones, if you are planning to use your space as a working garage. If you are using a dark tone, there's no need for a sealer but it doesn't hurt to apply it either. It's not expensive and it's easy to apply and wipe off.
As for thinset use the Kerabond/Keralastic system. Works great in weather changing climates.
T
toddcalo
michigan
How many feet of tile can be put down before a exspansion joint of some type is required ? Or is it required at all over concrete ?
Dakota00
Woodbridge, Ontario
If the concrete slab has control joints you "can" respect those joints by laying the tiles grout lines along them. Many, still tile over control joints with no ill affects.
If there's no control joints in the slab, none are required when laying tiles.
Herb67SS
Northern Virginia
Sealing is to prevent staining, I believe. If you use a dark grout, why sel it if it won't show stains? Soon as the weather warms up, I'm laying 1000 ft of PEI 4 porcelain and will use standard dark colored grout with 1/8inch spacing on the tiles. I don't plan to seal it.
I'm not one to just say search, but there is a ton of info on this site and much data re: tile. I can assure you, it's probably been asked and discussed on this site ;-)
noweare
Northeast
Sealing grout is over rated. I would use epoxy grout in a garage though. It cleans up well and will be able to take the winters better than cement based grout.
Dakota00
Woodbridge, Ontario
Epoxy grout is way more expensive, not very user friendly at all for those with no experience in using it. Very labour intensive to do the job and is overkill for a garage floor. But to each their own.
slickgt1
+1. Very expensive compared to the regular grout. I did it in my garage, because for me, it was a place to learn to use it. I have been avoiding trying it till I did my garage. Now I won't use anything else. I practiced on hidden areas. And if you mess up. holy ****, I was buffing 10 tiles for 2 hours.
Key thing I learned, do not let epoxy grout haze on your tiles like regular grout. You pretty much have to wash it off the tile right away. Even though you cleaned the tiles, do not walk on them, the epoxy leaves a sticky feeling film. So unless you want your boot prints all over your tiles, go away till it dries.
T
toddcalo
michigan
It looks like most of you guys are using glazed tile, the tile I'm looking at is a through body porcelain Pei 5 (no glazing) does anyone have any thing to say one way or the other, pros and cons. I have done some destructive testing on a sample piece the only thing I found that seemed to be a problem is welding spatter, It sticks to the tile then leaves a small divot behind when removed (will just have to be care full welding).
When I try to scratch it with a jack knife it dulls the knife but dose not hurt the tile ,it does however leave a little metal in the surface of the tile. That why I'm wondering if it would be worth the added risk of having a glazed tile (color body) for easier cleaning, or go with the through body (no glaze). Just looking for some input. Thanks
bdamico
i think you're wrong but dunno. throughbody here.
T
toddcalo
michigan
Anyone else have any input on (color body glazed) vs (through body not glazed) ?
Angelfire
New Mexico and Ireland
I would go the through body unglazed but I'm making an assumption that glazed will not have a good coef. of friction when wet.
Herb67SS
Northern Virginia
Dakota is a pro so his opinion carries some weight. I've noted that he has selflessly helped a lot of us amateurs on this forum. But I'm using glazed cuz I got it for less than a buck a square ft. in 18 inch square format. On a thousand sq ft that makes a difference. I'm also not using epoxy grout. I will use a very dark gray colored grout with 1/8th inch spacing. Epoxy would be overkill and an unnecessary expense in my opinion.
T
toddcalo
michigan
In the long run 10 15 years do you think regular grout will give any troubles?
what would be the best grout to use for a tight grout line .125 ? sanded or unsanded?
Any brand in particular?
I know I ask alot of ? but I really only want to do this once and not have any grieve down the road.
Dakota00
Woodbridge, Ontario
Herb,
Don't get me wrong, ideally through body would be the way to go for a garage floor. But if you got a great price on glazed porcelain tiles, which you did!! I'd be in your shoes installing them in my garage as well! ;)
Herb67SS
Northern Virginia
That's a great question. The tech data on most grouts say to use unsanded for 1/8inch or smaller joints, sanded for larger joints/lines. I'm not sure what correct answer is. Not sure whether it matters for that size joint.
Since I'm using glazed porcelain tile, I plan to do 1/8 inch joint and keep the grout high in the joints to hopefully reduce tile edge chipping potential from rolling steel wheels across the joints I.E. from engine stands, creepers, engine hoists. I THINK unsanded would provide the smoothest transition across joint lines, but again, the pros that do tile for a living need to weigh in and maybe provide some thoughts and guidance.
What I am certain of is that with very light colored tile and very dark colored grout, I won't be using epoxy grout. I put it in the same category as epoxy floor finishing. After you've done once or twice, the anxiety and concerns of doing it are GREATLY diminished. But for a novice doing a large floor, one time only, I don't need the practice. Nor do I need the potential work of having to fix what I screwed up with hours, days and weeks of corrective effort. Even though i will be having a tile setter laying the floor for me. Sh-t happens. I'm too old and life's too short for that. ;-)
KPSquared
Wetaskiwin, Alberta, Canada
Ok, so IF I wanted to seal the grout, which product do I use? I just dont like the idea of motor oil soaking into the grout. . .even if it is dark grout. (I'm planning on black)
Dakota00
Woodbridge, Ontario
Answers in bold
There shouldn't be any issues with regular grout not lasting that time period. I do suggest sealing the grout joints for added protection against staining. For all my exterior jobs I use Mapei UltraColor Plus grout. Which is an excellent grout with a stain guard protection with similar benefiting properties as epoxy but so much easier to work with. Especially for those with limited tile work experience.
For .125 which is a 1/8" joint. Sanded is just fine. Anything less I would mix the sanded and unsanded together to get the ratio I need for certain jobs. Using unsanded grout for exterior jobs I would suggest not doing so.
There's a few companies that make quality grout, I don't want to get in any debates regarding this. I use Mapei products, some use Laticrete and the list goes on...
T
toddcalo
michigan
Dakota do think the keralastic is required I about **** my pants when I looked into cost ,$150 for 5 gallons thanks Todd
Dakota00
Woodbridge, Ontario
Todd, if keralastic wasn't required I wouldn't be using it. Mapei is smart by pricing the kerabond thin set cheap but they rip you off on the latex. I suggest looking around for better deals from a tile supply shop not a big box store if you can.
I don't use 100% keralastic in my thin set mix. I usually mix between 60-70% keralastic with 40-30% of clean water, in a clean 5gal pail to stretch the keralastic. This also gives you more working time with the thin set as well. Do not mix a full pail, mix half pails and take it from there. Increase the amount you mix when you get a rhythm going, if needed. Also when mixing the thin set make sure to let the thin set rest for a couple of minutes and then give a quick spin again. This also helps the thin set to be workable longer as well. Follow the mixing instructions!!
KPSquared
Dakota - Still looking for a sealer for the grout. Any product in particular? Are all sealers the same?
Also curious - you reference "exterior jobs" all the time with your advice. Do you consider a heated garage to be "exterior". It will never freeze but is it just the use it sees?
Dakota00
Woodbridge, Ontario
Kurt,
Any quality grout / stone sealer will do the trick. Not all sealers are created equally.
Even when dealing with heated garages, I still use the Kerbond/Keralastic system. It's up to you if you want to "chance it" and use just regular thinset. I would still use some latex in the thinset just to help with strengthening the bond with the tiles.
Beaumont67
St. Thomas, Ontario
Kurt,
Great thread / Great advice !!
Kerbond/Keralastic system - I wish I knew about this a week ago & thanks...maybe next job.
Started doing a sun room with porcelain tile (12" sq. on sale for 99 cents each...LOWES).
Opted for expensive flex mortar, because my floor is semi floating, from the foam insulation put down.
(consisting of 1" foil foam board on cement / 3/4"" OSB Gold tung-n groove / 5/8" exterior plywood T&G)
- the additive would have saved me $30 per mortar bag, minus the initial system cost
FYI - Premium flexible tile mortar http://www.mapei.com/CA-EN/product-detail.asp?IDProdotto=100305&IDTipo=214&IDLinea=102
Kerabond/Keralastic System is a high-performance, two-part system: Keralastic ™, a second-generation “flexible” acrylic latex additive, is used to enhance the performance of Kerabond ™, which is a premium-grade dry-set mortar. This system has exceptional bond strength, flexural strength, elongation and freeze/thaw durability. To ensure proper flexibility, always use a latex additive when applying a dry-set mortar over plywood or to set nonvitreous tiles.
T
toddcalo
michigan
went on mapeis web site and used there grout calc ,12x12 tile .360 thick .150 grout joint
1800 sq ft it says i need only 10 gallons , this seems wrong to me? 180 square feet per gallon? this was for keropoxy. Any one have an idea if this is close to right?
Jsf721
LI, NY
I have had great results with a product called Miricle Sealants 511 Solvent Impregnator. I actually distribute this (disclaimer) and we spec if for the tile pre construction (only if regular grout is used) or after a deep and through cleaning.
Stuff is amazing and it last years. It actuall wears off as the grout wears off. Basically is pluggs the holes in the grout with a silicone type susstance so the dirt has no where to grab onto. I think it is a great product and when I re-did my bathrooms at home I did all the grout lines.
It is pricey but a little goes a long way.
duneslider
Riverton, Utah
I will try to hit several of your questions through out the thread. I have been a tile contractor for about 15 years. I currently do not do that as my profession but flooring is a passion for me. I have been all over the country learning about it. You will get a lot of opinions on what you should do, there isn't always "ONE" way to tile a floor. Every method has good's and bad's. You have to decide which route you want to take and what kind of risk you want to assume.
Liquid membranes are great, sure they add cost but for many reasons they are worth it. If I were doing my own garage I would use one. Will your floor fail because you didn't use one, probably not. I think they are good insurance. You wouldn't be using it for waterproofing reasons so you wouldn't need one of the "premium" ones.
Tile type Porcelain and ceramic are actually very similar. Porcelain is typically more impact resistant. I see a lot of talk about PEI IV and PEI V. I think there is a lot of misunderstanding on what that means. It is a measure of how durable the finish/glaze is. Basically this tells you how resistant a tile is to having its glaze scratched and worn away. It means NOTHING when talking about impact or compression damage (heavy stuff). A through body porcelain doesn't have a glaze so it should be a PEI V. A through body will hide damage better than any glazed tile but durability wise you wouldn't see a lot of difference especially if the glaze color is similar to the body color. Welding splatter is very hot and as you found can be hot enough to damage the surface, this is because it can be hotter than what the porcelain was actually cooked at. So, basically it is melting the tile. I would think that from the height of a typical welding table to the floor the splatter would cool enough to not do too much damage to porcelain tile.
Thinset You could write a book on thinset. Kerabond/Keralastic is an ultra premium thinset. If you were in a garage where you would have wet car dripping on the floor at night and it was cold enough to freeze that water I would say go for the K/K. If you won't be seing those conditions you may not need it. I have had great results with Customs Building Products "Flexbond". It is a polymer modified thinset with enough modifiers that it is more flexible than other thinsets. It is more affordable than K/K and depending on your needs may be more than adequate.
Expansion joints Yes you need them, especially in an outdoor setting. If you have control joints in your concrete, that is where you want/need them. ANSI and the TCNA call for movement joints every 8-12 feet in exterior applications, I have pushed those limits a little and felt okay but it sometimes keeps me up at nights :). Joints should be filled with a flexible sealant (colored caulk, although some urethane grouts are pretty flexible), or a commercially produced product designed for the joints. Do a google search for "Tile Tenting" and you will see why you need expansion joints.
Grout Lets look at this in a simple way. Cement grout is just like (well basically) the cement in your garage now. What happens if you don't seal it? What happens if you do seal it? Cement grout is extremely durable, it will pick up stains, just like your driveway does. Sealing helps prevent the stains and/or make it easier to clean them up later. Most sealers can't fully protect from acids and oils (though most do a pretty good job protecting against oils). The more you pay for a sealer the better it is. Basically there are two types of sealers, Impregnating and Topical. Impregnating carries something into the pores to try and fill them up so "stains" can't enter in. Topical sealers cover the grout so nothing gets into the pores. Topical sealers are the best at preventing stains but they typically change the "look" of the grout, kind of like putting a clear coat on the grout. Generally, the more expensive the grout sealer is the better it is. Topical sealers are generally less expensive. I typically do not like topical sealers but in a garage I would very much consider one because I think it would do a better job keeping stuff out of the grout. I have become very fond of Laticrete Permacolor grout for most all installations. It is kevlar enhanced, cures quick, has great color consistency, some built in stain resistance, sanded and can be used down to 1/16" joints. No other sanded cement based grout comes close in my opinion. (Miracle, Aqua mix, and Dupont all make great sealers) (I will echo Miracle 511 is a quality sealer) Again, the more you pay the better it is when talking sealers!
Grout Continued-Epoxy/Urethane Epoxy-Fantastic stain resistance. More work to put in and costs more initially. You don't have to seal it so after you start adding years and years of sealer in it does make sense. Typically, they are more flexible. However, epoxy doesn't like heat. The removal method is a heat gun and a putty knife. Weld will melt right through it. Laticrete spectralock pro epoxy grout is very easy to work with, almost as easy to use as cement grout but the technique is different and there is a little more rush to the process. (to dispel a previous comment, if the floor is sticky after is cause it wasn't cleaned thoroughly and epoxy was left on the surface)
Urethane grout-very easy to work with but does require a different technique than cement and epoxy grout. Flexible, dries quick, easy to use. Not sure on how it handles heat though.
Good luck, and feel free to ask any questions. I love to talk tile. I could bore you to death for hours!
T
toddcalo
michigan
Thanks duneslayer I've decided on a few things, tiles are orderd, thru bodied porcelain (no glaze) for thinset I'm about 90% sure I'm going to use keraply keraset no membrane in the plan at this time (although a local tile guy has some left over from another job I may be able to get cheap) a couple things I'm a little concerned with my garage is apprx 30 x 60 spit into 2 rooms 40x30 and 20 x30 I'm planning on putting a exspandsion joint in the door way between the 2 rooms so the max length of tile run would be 40 feet . my slab is cut up into life 7 foot squares so there is control cuts every where , the slab is about 6 months old. it would not be practical to honor these control cuts I'm planning on filling them with thinset, I ground the top of the concrete with a diamond grinder for a few different reasons.
Im undecided on the grout looking at keracolor with there maximizer or krapoxy, I guess i just don't want to have any regrets later, as for the grout as long as it stays in tact I dont think a little staining would bother me to much. does epoxy grout have better flexability than regular grout?
duneslider
Riverton, Utah
Ints. Keraply/keraset is a very low grade product. Keraply is not much better than dirt. I would never use it on a customers home. I would bet ultraflex I would be better, easier and cheaper.
I can almost guarantee you will get cracks sooner or later if you tile over the control joints in the concrete.
I haven't used mapei's epoxy so I can't say exactly how it is. I personally wouldn't use epoxy in a garage, maybe a car dealer showroom though. I couldn't justify the cost and extra effort. Generally speaking epoxy is more flexible.
KPSquared
what do you think about the kerabond keralastic? or is that a product you don't use often?
Umm. . .
T
toddcalo
michigan
opps missed that I guess he feels the kerabond system is probably over kill but the keraply is garbage , keraply is mapeis next best as far as I know. so I guess if you want to use mapei the choice is kerabond?
duneslider
Riverton, Utah
Keraply would not be their next best, their next best would be something like ultraflex III. Keraply and keraflor are not quality products and it is a disappointment they even sell them. People are misguided by the way they do their marketing too.
Kerabond is a high quality dryset non-modified northern. Keralastic is a high quality liquid latex additive. It creates a mortar that is flexible and has a high bond strength.
Ultraflex III is a high quality modified mortar which means it had a powder polymer modifier mixed into the bag. It will have a high bond strength and some amount of flex.
Ultraflex II just has a little less polymer in the bag than its big brother.
I have used pallets and pallets of ultrflex II, k/k and UFIII are for projects with special needs.
I still think customs flexbond would be a great mortar for you project.
T
toddcalo
michigan
Thanks for clearing that up, Im not so sure that custom building products flex bond would be available by me?
duneslider
Riverton, Utah
Home depot, dal tile, I am sure there are other tile shops in the area that carry it too. Home depot is easy and the prices are not that bad even compared to my contractor pricing.
