rjy86
i have never welded before but want to learn and i have seen welders at harbor frieght for like 129-170 bucks from 90 to 110 amp. .what size will i need to weld parts like brackets for mounting motorcycle seats, fenders etc.? im not gonna build any frames just want to be able to fabricate small parts or weld tabs for mounting to my frame ,things like that. will a flux welder do the job?, or do i need to run gas? and whats the smallest amp,voltage and all those other specs i need? i want a wire feed cuz that seems to be the easiest to learn with ,but i dont know the difference between mig and tig and those other terms..? i do know that if i dont use gas i have to use flux wire, but will flux hold anything? is it as good as welding with gas? it seems to be less hassle. i just need some basic info on what i can get away with for the least amount of cash. im just starting out so i dont want to drop alot of money on somthing, but i dont want some **** that is useless for fabricating. also if iwant to weld stainless or aluminum can i get ss or aluminum flux? or do i have to buy the correct wire and gas for each app and do i need a special welder or can i just use the correct wire/gas or flux with any wire feed welder? thanks for any info im not even sure this is the right place to post this. thanks again for the education.
because only that person knows what they want to do with it? $$$.$$ is what you need to think about.
Then you can get a 110 cheapy and weld nicely even to 1/4" - and if you need to weld more, go back to the oxy-A! I put 220 in my shop, have welded qtr panels, floor pans and more with the 110 and frames and heavy stuff with the Oxy-A. I have yet to want a 220machine enough to shell out $700.00 - but then I'm cheap! If I could find a 220 used for 200.00 I'd be all over it.
