This drill press was left behind by a vinyl company that previously occupied my company's new building. They had no way to unload the machine at their storage facility and so it was tucked away against the wall until they could find a buyer. After finding the contact information for the owner I called him and he informed me the machine was used to mill slots in various vinyl pieces and was fairly babied as they had a Bridgeport for any serious milling. After inspecting the machine and measuring the spindle end play and run out I called the previous owner back to negotiate a price and became the machines new owner.
Loading was made easy by the forklift/boom combo and the press made the 10 mile ride home no problem with the help of some straps and scraps of 2x4.
Unloading proved to be slightly more difficult as my shop only has 9ft ceilings and the press is about 6ft tall. This didn't leave enough room for the backhoe. Once I finangled the press as far onto the floor as I could used my engine hoist to take over lifting duties. Turns out Harbor Freight didn't have this specific task in mind when they designed their POS. By tilting the drill I was able to use the hoist along with a floor jack to roll/drag/scoot/curse the thing to the middle of the floor.
I have no photos of the rolling/dragging/scooting/cursing phase of the operation as I was too busy with the cursing aspect of the job. Once in the middle of the floor I put the 1/3HP Craftsman beside it for comparison. On the left old and busted, on the right the new hotness.
The research I did before I bought the thing shows that it was originally made in Sweden by Strands and imported by Wilton. The XY table is made by Demanders, another Swedish company. It has a 2 speed forward/reverse motor with 4 different gear ratios in the head, 4 power feed speeds and a hair over 5" of quill travel. Both the head and the table crank up and down the column. The motor is rated for 2.5/3HPand it will turn a 1 1/2" drill bit using the hand feed.
So far I've rearranged my shop to make room for the drill and the phase converter I'm building for it, and I disassembled, cleaned, and reassembled all 200 lbs of the XY table. My next step will be to crack open the head and relube everything. I will wait til I have a proper shop before I completely overhaul and repaint the thing.
If anyone has information about these drills I am all ears.
