Simple dimmer question
rackeu
I replaced a switch with a dimmer to a bathroom light. Two wires on the switch, two wires on the dimmer. Should be simple.
Light turns on and full brightness with dimmer slide to the max. Try to slide for less light output and the light goes out. In other words the slide powers the light for the first 1/16th of an inch and throughout the rest of the 1/2 inch slide, the light remains out.
What am I missing?
Also it's an over vanity light with 4 40wattt bulbs.
Thanks,
Tim The Tool Man
Lehigh Valley, PA
Sounds like your trying to dim a CFL?
^This. Many new fixture either come with CFL bulbs or they have a stupid prong base that force the homeowner to buy CFL's.
Even if you buy the special 'dimmable' CFL's, you really won't be happy with the flickering output...
Either that or you have a bad dimmer switch!
ddawg16
S. California
Considering the cost of dimmable CFL's, an LED is not much more....and will last longer and dim down further...
Also, make sure your using the right kind of dimmer. Lutron has a new dimmer that is pretty much universal...works on CFL's, LED's and incandescents.
R
rackeu
Yes it is with incandescent bulbs, not CLF.
It must be a defective dimmer.
I did paint the dimmer as the wife wanted to have it match the walls, could that possibly have something to do with it?
rlitman
Long Island
Painting the coverplate is not an issue, but the face of the dimmer is usually a heat sink, and that shouldn't be painted.
bdamico
switch the bulbs, take out half the bulbs, switch the dimmer--just troubleshoot
