Is this okay -wiring a ceiling fan
darcyh
London Canada
Hello:
Can I run 14/3 to a ceiling box for fan and light. The fan has separate circuits for the fan and light.
Wall switch box will have:
- incoming 14/2 white / black romex always hot
- outgoing 14/3 romex
Can I:
- pigtail incoming white to outgoing white on the 14/3 and connect to white wires for fan and light at ceiling box
- split incoming black to two switches at wall box
- connect outgoing black from switch one to black on 14/3 and connect to fan motor
- connect switch two to outgoing red on the 14/3 wire and run to light on fan fixture
Sorry to be so wordy...
Thanks
Dave
Tim The Tool Man
Lehigh Valley, PA
Yes. If what you are saying is that you will be replacing the standard toggle switch with a fan switch. BUT you need to make sure the existing ceiling box can support a fan.
FROM THIS:
TO THIS:
FOUND THIS, NOT MY DRAWING:
Charles (in GA)
50 mi south of Atlanta
Thanks
Dave
Not at all!!!! Rather, clear, concise, and to the point, using correct terminology. Best electrical post in months.
Now someone will parachute in with the suggestion that you cam buy a special switch and control box at the fan that allows all of that to happen with just two wires rather than three.... or a hand held remote control that does the same..... even though its clear that you know what YOU want to do...... and avoid stupid, failure prone electronics gadgets for the future.
Charles
Teken
The Bad Lands
Charles
:lol_hitti
Teken . . .
Jefe
OH-IO
This is exactly how all of my bedrooms are wired. It's very convenient to have the separate dedicated switches for fan and light.
D
darcyh
London Canada
Thanks guys; especially Tim for the diagram and Charles for the kind words.
Advice appreciated. Will proceed with installation.
Regards,
Dave
