young buck, you gotta find some old Ridgid wrenches, they are the best!
I know, mine are alright but not holding up the best. I've got to find somewhere that sells themif you completely tighten the nut it´s locked and you have to open the nut again to remove the wrench. But you could slightly loosen the nut and use it like a ratchet, like the Knipex pliers wrench.Monte---How "fast" are those pliers-style of 'pipe-wrenches' to use???
If you had to fasten, and un-fasten each spin, they could sure slow a guy down, but the thin jaws sure would be nice in some tight spots....I've had to hook up well over 100 unit heaters/univents, and they always are in horrible spots...smaller jaws would be a big plus.
Never understood why RIDGID hasn't come up with a thinner jawed version of a pipe wrench. You would think with the newer alloys, something like that could be done.
Monte, what's the brand name on those blue locking pliers type thin jaw wrenches? i need one badly.
I do get mad at computers from time to time!! That pipe wrench would come in handy haha
This one is more suited to my needs though...
Started out as a sprinkler-fitter when I was 18, regularly used a 4' ridgid compound leverage wrench ( 2 piece wrench that chains around 1 part with a lever action piece that attaches to the 1st part) on a rolling staging while screwing together 6" or 8" pipe to fittings,damn wrench weighed almost as much as I did back then. I'll have to see if I can find some pics of 1
Armstrong stuff is usually expensive, too!
See post #26 on page 2 of this thread. I took some pictures at our shop of the tool room full of pipe wrenches. One of them is of some huge compound leverage wrenches
Was told at the time when the Vietnam Nam war was winding down, the Schick razor company was manufacturing helicopter blades for the military and had a bunch of special aluminum left over and used it to make a bunch of tools.
Here are two of my 15 or so pipe wrenches that I have. I bought the 6" at a pawn shop. I like small wrenches. The 48" cast iron one and most of the others I have came off my father-in-laws steam locomotive. And YES I used the 48" a lot on the locomotive. It is heavy and took two of us to get it up on the engine to take the saftey valves off. Partially because it is heavy and partially because we were having to lift it up over our heads. It took two of us to use it!
I like using the 6" the best.
John
I'm with you!!!
I much prefer using a 6" over a 48" or a 60"....
I've gone so far as to put a 10 to 15 foot cheater on a 48 to get relief valves off of boilers......not fun, bet we usually get it!
Haven't seen any pic's of anyone using a 60 yet, nor any comments on 'em!![]()
I'd a quit working on the engine if I had to use a 60"er. You can see we put a pipe on the handle a few times!
Since you have some steam experiance.... I am trying to get a adaptor out of the end of a locomotive whistle. I can't budge it. Any suggestions other than heat?
John
that usually works for me.have you tried a combo of Kroil, heat and swear words?that usually works for me.
John
from the Ridgid Catalogue
What makes that 2" union so rare???? I just installed 4 of them last week. Looks to be a black malleable union, but it could be brass and has just tarnished with age.
Think I would use heat too, since the whistle looks to be brass, with the close ****** and the union being black iron.
The bad part, looks like an old recipe of cement/linseed oil was used as a pipe dope, which was very common in steam piping use of days gone by.
Sure was/is a pain to get off. Heat will do the trick though, since brass will expend much farther than steel....you get that union half heated up, it will most likely turn right off, just be careful where you put that wrench, so you don't crush the whistle. A pipe vise would hold it better, maybe even hold it wrapped in something, if lead wouldn't melt...? Lead sheeting that is.
... Virax...Connex
Two new brand names for me!
Are they made in Germany or Sweden or elsewhere?
