Enclosed nut and bolt storage
jcp907
Seminole County, FL.
I want an enclosed nut and bolt (etc) storage system and I don't want to spend a ton of money. I hope that some of you may have ideas.
I want drawers with dividers or bins. The slides don't need to be roller bearing and the drawers don't have to be metal, but the individual plastic bins are not what I want. I also don't want a flip up cover for each drawer.
At our Lowes, their nut and bolt display cabinet is pretty much what I want (the drawers aren't for sale). The drawer sets are modular. I believe 6 drawers to a section or so. Each section is probably about 30" wide and maybe 19" deep or so and might be 24" tall. Maybe I can take a picture of it next time I am there.
Does anyone have any idea where I might find something that's not terribly expensive?
Thank you,
Jay
bobs409
Pottsville, PA
I don't have any pics handy but I built my own fastener storage drawers. I built my own workbench and it has 20 large drawers on full extension 100 lb drawer slides. I simply made dividers inside the drawers I wanted to use out of 1/4" hardboard. These were half lapped over one another. One drawer even has a sliding tray built the same way.
Building this all myself, I could make it any way I wanted. I can easily make changes as needed and it wasn't too costly. (the drawer slides are the biggest cost)
Something to consider if you have some woodworking tools and like to DIY.
Bob
P.S. I would recommend some type of good slides as a drawer full of nuts/bolts is quite heavy.
daw53
The good stuff is not cheap. Durham makes a nice line of such cabinets:
http://www.durhammfg.com/catalog.html?id=1
I have some 'drawer cabinets' similar to the Durham ones pictured that I use for fastener storage. I got mine from the plant that I used to work at.
I have also built storage drawers similar to what jcp907 explained.
- David
Ramblur
Central FLA
I picked up Dorman cabinets for $10/pc. from a parts store that was closing
and the paper size drawers next to them from a HR Block outfit that was
moving.Keep an eye out and something will turn up.
Stuart in MN
Minneapolis
I see those file card cabinets like Ramblur posted in his photo for sale on my local Craigslist every so often, I think they'd work pretty well. You could make some drawer dividers out of sheet metal or thin plywood to suit your inventory of hardware. You may be able to find some in a used office equipment store as well.
Edit: Here's a perfect example of what I was talking about:
http://minneapolis.craigslist.org/fuo/842983656.html
I like this one even better, but it's a little pricey for garage use... :)
http://minneapolis.craigslist.org/fuo/846044670.html
ddawg16
S. California
I like the yellow portable storage cases....black case, clear cover with different size yellow bins. I have a couple and they are loaded according to use...one has wood screws and related hardware, the other the general purpose screws.
As soon as my garage is finished I'll buy more and make a rack to store them....what I like about them is that I can pull one out with the screws I want and take to the task at hand instead of making mutiple trips.
J
jcp907
Thanks for the input and advice.
Bobs-I wish I had the skills, tools, patience, and time to build something like this of wood, but time and tools aren't available at this time. I already have too many projects, including the garage! Thanks for the advice though.
Daw53-yeah, I know the good stuff isn't cheap when new. I don't need top of the line though, and I don't need new. As Ramblur's experience indicates, the deals are out there, I just need to know what to look for. I will add Durham to the search terms-thanks!
Ramblur-Thanks for the hope, something like those Dorman boxes would probably be great, particularly at that price. Is it possible to open one of them and take a picture?
Stuart-thanks for the advice and I have two such cabinets. Sorting through them is a bit frustrating for me so I am now looking for full width drawers, so when I open one, I can see everything in it, instead of looking through three or four columns of drawers. I realize labels could overcome that, however, it's just my preference to find a wider drawer. Thanks for the links and the pictures.
DDawg-Thanks for the advice. I have some of those as well and use them right now and they work well and I will use these for the trailer, but want something easier than having to slide each case out, then look inside, then unlatch, and open, then close and latch to grab what I need. I guess I am getting lazier. I just want something that's more efficient
It looks like there are deals out there, and I have the time to wait to find what I an looking for. I will keep an eye out on Craigslist and Ebay like you guys suggest-searches will include lista, dorman, vidmar, durham. Does anyone have any other ideas for search terms?
Again, thanks for the help guys.
Jay
Mr_fixit
Rustylvania
I use boxes like these. http://www.durhammfg.com/item.html?id=156 I find them in the junkyard in old CATV or Phone Co vans or at flea markets. My favorite ones are 12" long and about 4" deep.
I also find them used at Carlisle or Englishtown swap meets . I've bought new ones for $50., but most used ones cost half that. You can never have too many bolts/nuts/screws, etc!. I have about 15
ultgar
New Jersey
I have a bunch of large and small Durham scoop boxes...some new, some used that I am selling off. Also a few of the slide racks which house 4 of the boxes.
Contact me directly at [email protected] if interested. Steve D
Brad54
If they don't have to be drawers, you could get a regular and readily-available nut and bolt bind. Doesn't have the advantage of sliding out to look down into it.
Then make a pair of doors out of clear Plexi-glass, with a couple of cabinet door knobs and magnets to keep them closed.
I got a big 48-bin cabinet, took it to the soda blaster and had it stripped (that was a little above-and-beyond, but I know the guy so it was cheaper than buying new), and painted it with red Rust-oleum. I need to get my "round-toit" and build the doors.
I've also got three of the plastic storage bin racks that hang 8 plastic bins off them. The bins are removable. The racks are flat metal, with rows of 3-inch-wide louvers punch in them (Upside down, and backwards, to form a lip). The bins have a plastic tab on the back of them that hangs into the lovers. This is what holds them to the panel.
I put these in an old industrial metal cabinet with a door on it, and use it as my nut/bolt magic box.
It's not ideal, hence the nut/bolt bin I'm working on. But it's worked great for 10 years, and has kept all my fasteners dust and dirt free.
That's actually the key right there--10 year's worth of shop dirt and grim settling into a bolt bin will make them grungy every time you dig into it.
-Brad
kbs2244
If you are near a large city, check the yellow pages for a used office furniture place.
Or keep an eye on your local craigslist or e-bay.
Good office stuff is almost always steel with roller bearings.
My favorites are library card files, map or drawing cabinets, and if you can still find them IBM card cabinets.
Jiffycake
Wow, ultgar. Do you sell any of your stocked hardware? You should get a collection of gr5 and 8 hardware. I would buy it lol. Ace doesn't always have what I need in stock.
69charged
carberry, manitoba
this is what i bought. it was 299 including all the bolts from 1/4 to 3/4" grade 5 hardware.
clarence
****, pics are at home. i will post shortly
Brad54
here are those pics.
That's like the new/old bin I have that I blasted and painted red. Make a simple set of clear plexi-glass doors for it: it'll keep dust and shop grime out. That doesn't sound like a big deal, but think about all the paint dust, sanding dust, oil particulates, any wood dust, glass bead dust, soot from welding and torches, etc. for 20 years. Or even 5 years. Eventually, your hands will get grimy every time you dig through them.
I also have plexi glass doors on the metal book case I keep all my reference books, shop manuals, etc. in.
-Brad
ultgar
New Jersey
Unfortunately, all I stock is metric hardware....grade 8.8 (gr5), grade 10.9 (gr8) and grade 12.9 (gr10). Also have some stainless. Over 1m pieces if you include the Spax inventory of screws. SD
kbs2244
1320 has the right idea.
Find the auction sites in your area and be a regular on them.
Not just gov, but big schools, big companies, etc.
In my area the U of Wisc. has a good site.
J
jcp907
Ultgar awesome, would love it. Keeping an eye for some used ones, even if they are a little beat up. I am a bit constrained by budget, but don't need something right away.
1320, great idea. I am in Orlando. Some local dealers are closing it's doors, so there may be some items to score, the hard part is finding out when and where the auctions might be.
The bins might be fine if I cover them with plexiglass doors. 69 Charged, where did you buy that?
Thank you,
