mobiledynamics
I've need to order either a 1 1/2 socket or 1 7/16 socket to tighten the nut on a trailer ball to 250 ft. My caliper shows it's a hair under 1 1/2 for the nut. Hate to order the wrong size. ...
Wrench size is 1 1/2 times bolt diameter. 3/8'' diameter bolt would be
1 1/2 x 3/8 = 9/16. This is for standard nuts. EXTRA heavy is larger. I think for extra heavy you add 1/8'' to the standard nut size.
Use a regular 12"+ pipe wrench. They open big enough, stick a pipe on it and go to town. I've always used a pipe wrench and a 3' pipe over the handle. Makes it real easy to pull the ~80 ft/lb at the end of 3 feet one handed!
Another vote for a pipe wrench. I put the receiver in the hitch on my truck and use the pipe wrench to tighten it down.
If you change hitches much, this eventually leaves bite marks on the nut that turn into metal splinters.
