bobj49f2
I have a big problem. My son is a dairy farmer. He started his operation about two years ago. The problem I am having is with the silo unloader. The farm is run on 120/230 single phase. The silo was built before I came to the farm, more than 25 years ago so I'm guessing it's about 35 years old. They seem to always have trouble with this motor. Originally the silo had an 8hp motor but my father-in-law upgraded to the 10hp. My son just had the motor serviced and the orginal three position switch, "Forward/Off/Reverse" was toast. This is a rotary type switch. Because no one makes this kind of switch any more because of liability reasons I am forced to build a new control system to control the motor. I build and install industrial control systems so building a control system is no problem.
The real problem is the cost and time. So far I am having a problem finding a four pole reversing motor starter. I can find three poles in stock at my vendors all day on their web sites, no four poles. I have found four pole contactors which are special order and I could build a reversing motor starter but because this is a 10 hp motor and pulls 50+ amps. The single contactors are in the $400-500 range each and have a 1-2 week lead time. My kid needs the silo running ASAP. Because the unloader is down he is buying corn at $500 a load and it only lasts him a couple of days. Since we got the motor back I can rig it up directly to the circuit breaker to make it run but it is not the correct or safe way to do it. This motor is under a big load and it won't have any thermal overload protection, just the circuit breaker. It also has to reverse when the unloader clogs to loosen the load.
Anyone out there with a similiar situation with a big motor like this and what did you do? No matter what I won't have a control system built for at least a week even if I could find all the parts. He's operating this operation on a very narrow profit, actually no profit right now. Anyone know of a supplier with four pole motor contactors in stock?
