Hey there,
As we all know matco/gearwrench/armstrong ratchets that have the 60 tooth kits can be swapped out for the 88 tooth kit and vice versa. I have done this before switching from 60 to 88 and 88 down to 60.
Well I placed an order from tooltopia for a gearwrench ratchet kit 60 tooth for my matco 3/8" BFR8TG which is a 60 tooth ratchet
I ordered (2) 81227 kits (60 tooth) and received them only to notice that they were actually a 81227F kit (84 teeth)
http://www.tooltopia.com/gearwrench-81227.aspx
I was going to call tooltopia tomorrow, but decided to see if a 84 tooth kit would fit in a 60 tooth ratchet.
Surely enough it did and works
In conlcusion 60/84/88 should be interchangeable
If you want to go from 60 to 88 you can and from 60 to 84
I can only prove this for the 3/8" drive ratchet
84 tooth ratchets are craftsman premium and newer gearwrench
88 tooth ratchet are newer armstrong and matco
60 tooth ratchets are older armstrong, matco, and gearwrench
Included is 2 pushers and 2 springs ( I only used 1 of each)
Thanks!
Thanks!
