well now that I have done Black pipe install, I thought I would give a update
Black pipe is a lot of work, particularly when you do 1", 3/4" is MUCH easier to work with, and by that I mean it is much easier to cut, thread, handle and tighten.
that said, even at the price of copper being right at 4 bucks a ft for 1" copper and just over 2 dollars a ft for 3/4" copper around here, (home depot had some 10 ft sticks in 3/4 1.79 ft) but did not carry the higher grade in 3/4,
I think there was very little money saved going to steel. even though the steel prices where just over a buck a ft! that is unless you have plenty of time and do not pay anyone to help do the install, and also just straight runs with little turns,
anyhow you have a choice, black pipe or copper, black pipe is cheaper even same sizes, black pipe is much cheaper when you go to 1" diameter sizes and that was my deciding factor.,,,,, but the time involved is far greater than I would have thought, and if your paying someone about 10 bucks a hour for labor help, your not saving anything. even if you payed someone the same to help install the 1" copper, I thought the time difference would had payed for itself
would I do steel again? it all depends on the layout, if in a empty building, to run all the way around a perimeter, I would say I might, only if I did not have to pay for help. and would definitely if doing over 1" pipe, but if it came to the point of having to do a lot of cuts and threading, (plus remember using a pipe wrench on every drop is a lot when you make the t's go up to draw air from the top of the pipe) I would say not no, but HECK no! .... that is if you think you can braze/sweat the joints! plus the copper will look nicer over time I think.
again thanks for everyone's help, I learned more than I thought I ever wanted to know about pipe, (be it copper or steel) . air flow, the benefits of larger diameter pipe and moisture. my install was not the typical shop install as I have a CNC plasma table at the furthest point, when you are running constant air (think holding a blow gun wide open ) all the basic pipe requirements are thrown out the window with larger diameter pipe the air will move slower, less moisture in the line,, less psi drop at end run. at a given cfm ,
did I go over kill with the 1" for my needs? perhaps, but not by much, where I used the 3/4 to run the last 60ft or so and for the drops
and my tidbit on the pvc users such as I was, while taking my down, I held a t in one hand while unthreading a bushing (where a hose quck disconnect was) and the T split , it would have been a very short time before the air pressure blew that T apart, in fact might have the first time I put 150 psi to it, that t was head level , I'm glad I did not pressurize my pvc with the new higher pressure
