I received an 8" Delta Bench-Top Drill Press in exchange for some work I did.
I have a drill press so I thought I'd freshen this one up and give it to my son.
Most of the drill press will clean up with standard clean-up/lube-up techniques but I have questions about parts of it. The base, table, and column are all bare metal and have a pretty heavy coating of surface rust on them. I figure that I can clean them up pretty good with #0000 steel wool and WD-40 but need some advice on what to put on them to keep them from rusting again but that won't be a sawdust magnet. Any good suggestions that you guys have used would be appreciated.
Thanks,
Thanks,
