Another tire Machine thread, HELP!
pumalex
Quebec, Canada
OK, i'll try to make this short, i will be doing maintenance on a fleet of about 8 cabs who change tires 3 times a year. I will also be doing my personnal cars and friends and family so this is going to be a really light duty use of the machines.
The thing is that i have a Porsche and a couple of friends who have race cars and wide wheels (19x11 on mine for example). So from what i understand, it is impossible to change a tire on such a wheel if you don't have all those assist arms.
I want to buy used as i don't want to spend 5k on a new set of average quality, i beleive i can buy used and have better quality of the brand at least.
Two options on the table for the tire changer, one is to use a regular one and have a shop do my fancy wheels and the other is to buy the fancy machine right now.
For the regular type, what i have found in the classifieds so far that looks interesting are:
Corghi 9820 for 1350$
Corghi 2000 for 1300
Hofmann 1610 for 1100$
Hofmann 3300 for 900$
coats 5030e for 1000$
coats 5060e for 1800$
For the types with the extra arms for the wider rims and run flats i can have
Corghi 2019 for 2800$
Coats 9010E for 2500$
technotlift TC2000 (this is a chinese type i beleive but almost new) 2000$
So, given my situation, would you pay the extra money to get a fancy machine or just send the harder tires to a real tire shop?
If aynyone has comments on those machines or experience or knowledge on what is different from a model to the other, please HELP! I am so lost, i know nothing about those machines and what to get the best quality/price deal.
I'll make an other thread later for the balancer to keep it sample.
thanks a lot
Skyking1992
pumalex,
I have a John Bean (Snap on) machine. No extra arms or assists. I regularly change tires for my Corvette. I run 18 x 10.5 rims and 315-30-18 Hoosier tires. I have no problem mounting or dismounting tires due to not having the extra arms. Run flat low profile tires might be tougher. The only problem I have is the machine is not quite tall enough. When I get the tire off the rim, the combined height of rim and tire is right at the height of the arm. I have to yank a little to get the tire out from under the arm. If my rim were even another 1/2 inch tall, I think I would be in trouble. I have thought about making a 1 inch spacer to lift the entire upper assembly up. My explanation is probably clear as mud - I'll see if I can get some pictures tomorrow.
Skyking1992
P
pumalex
Quebec, Canada
thanks for the feedback, if i was able to save myself the headache of having all the extra arms, that would be nice as i don't care about the run flats. Anyone else has similar experience? I have never mounted or removed a wheel so i have no clue to be honest.
thanks
Graham08
Iron Station, NC
I've mounted a bunch of right rear tires for my pavement sprint car on a Coats 4040. They go on a 15" x 18" rim. The only "special" piece required for the tire machine is an extension on the center post.
theoldwizard1
SE MI
Coats 4040 are great for steel rims. With some extra padding and careful operation you can use them one aluminum rim without scratching them up also.
That machine will last a lifetime.
mattmankow
Westminster, Maryland 21158
Being that you've never mounted or dismounted a tire before... Get the 4040 to do the cab tires (usually under $500, and bulletproof), and leave the fancy wheels to the professionals. They damage them, they buy them.
What about balancing?
tdkkart
Eastern Iowa
If the Taxi-cab thing is gonna be a long term deal, that's over 100 tires/year if you throw in repairs, plus your's and your buddy's stuff, I'd be taking a serious look at a new machine with the goodies you need. Screw up a couple high $$$ rims and you'll wish you had.
I'd spring for a Coats, I've seen some reliability problems with some of the off-shore stuff, and it's not like I see alot of tire changers, so if I see the issues there's probably a trend.
P
pumalex
Quebec, Canada
I will need a balancing machine too, just didn't want to put too much variables in one thread... i'll look into balancer after, i am already pretty confused.
MG44
I have two tires machines, a TC950 and a Coats 20/20. The TC950 is actually a very nice machine for being chinese built, I have had it for over 3 years that machine probably changes 20 tires a week. We aren't a tire shop per say, but we up sell a lot of tires as a service to our customers. The TC950 is advertised to handle a 15" wide rim. It has a bead seater on it which is handy on truck tires. The machine was under $1600 brand new.
I also have a Coats 20/20 that we have had for ever. A Coats 20/20 will handle up to a 17" rim, and any NAPA carries the protector sleeves for the mount/demount bar to use on aluminum rims. I am not sure how WIDE of a rim you can do on it, but I know I have done atleast 9 inch rims without a problem, I wouldn't see an issue with a few other inches. My machine does not have a bead seater, but I think some did come with them. I don't know about finding one for under $500 because in my area these old Coats machines still command a high $$$ amount.
As far as tire balancers, I have been in this business for a while. A spin balancer is a spin balancer is a spin balancer, unless you are getting into road force. I currently have an Accuturn that is about 6 years old and works fine. It will do up to 24" wheels. Some balancers are so cheap ($1100) new that it is not even worth buying used. I did buy my Accuturn used only because I knew the shop it came from, and they upgraded only because they made too much money last year, and the tax man told the owner he better buy something.
Graham08
Iron Station, NC
The Coats machine I was using didn't damage my wheels, which are aluminum, but I could see how they might if you had something with clear coat or anodizing on the outer rim.
mattmankow
I have a very used 40/50 in home garage. Basically same as 20/20, 40/40, etc. I've done 16" dually wheels, 17" Subaru alum, and a lot of the generic steel stuff. For a cab fleet with steel wheels it would be perfect. I bought it for $350 from a votech that upgraded their equipment.
I also have an older Hofmann balancer. This was top dollar in its day. Great balancer from ebay $600.
I would still recommend you to sub out the race stuff. I have used a lot of tire machines when I was still working on cars as a profession, and there is much room for problems with the low profile tires. Experience is key here, and you won't get much. IMHO
