Sweeping the floor
galute
Bald Knob AR
What kind of broom do you guys use to sweep the floor with. I've got a decent push broom but it is near impossible to get the floor clean. Every time you push it forward and then bring it back it drops dirt back on the clean part where it hits the floor. It's very aggrivating to have to keep sweeping the same spot several times just to get it clean. Any good broom suggestions?
Beytill
Flatlands of Il.
Shop broom,2' wide. The trick is to brush forward(sweep) then tap(bounce) the broom on the floor (just behine your pile) releasing the rest of the dust. Repeat
SARG
Northeast
I have easily five different types of push brooms and inevitably I end up "pulling" the broom rather than pushing.
bobadame
I've used sweeping compound. It's saw dust that's treated with something. Sprinkle it all over the floor and sweep it up. Dust sticks to the compound.
G
galute
Bald Knob AR
nothing works better than a small soft bristle hand brush.. it ***** but thats how I sweep up all the time.
That's what I use when I want the floor clean. Sure takes a lot of time tho.
I use that method too. Still don't work that great. No matter how many times I tap it I still get a spot of dirt back in the clean area. The problem I have is between my tractor, 4wd's, 4 wheelers and muddy boots I end up with ton's of dirt in the floor.
I do that sometimes but I am tall and the broom hits the floor at a steep angle. Unless I do a lot of bending over to lessen the angle all it wants to do is skip.
Jackfre
N CA
This kinda depends upon the finish on your floor. I've used the sweeping compound you can get from HD or Lowe's. That allows vigorous sweeping without getting the dirt airborne. I use two different brooms. One coarse and another pretty fine. Push and Pull. Finish with a shop vac.
Winmon
Sequim, Wa
I have just been using a standard medium stiff bristle push broom along with a basic broom. However, after recently doing some woodwork which created a ton of dust, the push broom just was not cutting it. The saw dust was just sticking to the floor. After remembering how well grocery store type dust mop style brooms worked when I used to work at one I went out and bought one for the shop. Works great! The dust sticks to the broom like a magnetic. After each pass with it I just shake it out at the spot of collection. And when it gets really dirty you just throw it in the washer. You can buy them at Home Depot and janitorial supply store. I went with a 36" but they have them in 48", 24" and shorter lengths.
http://www.uline.com/BL_7000/Dust-Mops
Todd.Brock
Cincinnati
I use a shop broom from SAMs club. If I had a painted surface, I would be all over the dust broom referenced above. Just like the old days of pushing one at the hardware store.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Unscrew the handle and turn your broom around. It may take a few times of sweeping to get it to work where you want it though. The bristles of a broom will take a set after using them in one direction for any period of time, and especially if you let the broom rest in the corner of the shop setting on the bristles. You can almost double the life of the broom by switching it on the handle every couple of weeks.
And as far as sweeping compound goes, it works very well. We would use it at work every couple of weeks in the department. I think the brand name was Cotto-Waxo and we bought it through Grainger in something like a 50# box. It is basically oil soaked sawdust. It will pick up all the dust where you sweep. A box will last for quite a long while. Maybe a year, as it doesn't take much. If you put it down too heavy, just have another container to throw it in and use it over.
GRX
MD
^^ this.
Since this is the garage section, I assume we're not talking dusty kitchen floors.
Use a straight broom to push dirt from confined side areas toward the center areas first, then use the push broom from there.
HMCFab9
Fox valley area, Wisconsin
when you are done sweeping, flip the broom over, or hang it up.
If you leave it sitting on the broom part, it bends the bristles over & it never works good again.
ZRX61
Solar Blight Valley, SoCal
I've been using an 18V cordless leaf blower, gets everything everywhere..under the bench and tool box, in corners and blows it right out the door
That's the rookie method.......this is how ya do it
https://sphotos-a.**.fbcdn.net/hphotos-ash4/3521_10152086063965016_1866447161_n.jpg
mrodgers
French fries on salad, PA
Shop vac. At work I expand foamed plastic beads. It gets everywhere. Most folks in production use air to blow it out in the aisles and we have a ride-on sweeper. I work R&D and my equipment and areas are much smaller. I am always shop-vaccing the floor.
At home, I just do the same thing. I shop vac the floor all the time. I have terrible allergies and the dust from a broom or blowing with air kills me. I love my shop vac.
Because of my constant heavy use, I'll tell you, the best shop vacs (OK, reminded of the hot water heater thread, I should call it a wet/dry vac....), so, the best shop vac is the Rigid 16 gallon. I've had Shop Vac brand, Craftsman brand, the Lowes vac, many different vacs at work. Most of them lasted months before they stopped working. We finally bought the Rigid and use them for years (I vacuum out plastic beads from our large net bags that hold materials when I am doing cleanouts changing product. I may be running the shopvac for over an hour straight.) The only problem we've had with the Rigid vacs are the switch and the plug both get hot with hours of constant operation and we replace them with heavier duty plugs and switches.
Our extrusion production department have 16 gallon Rigid vacs connected up to the screeners that screen out under and over sized pellets and they run continuous for hours on end. We could never do that until we bought the Rigid vacs. All other vacs would last mere days.
Disclaimer, I am in no way affiliated with Rigid. As a matter of fact, my wife works for Lowes. Even so, everything I buy, I pretty much buy at Home Depot, LOL.
nehog
Jaffrey, NH
Style is success, and this post tells it all. Nothing wrong with your broom, just use it properly and you'll do just fine. Push, tap (or even double tap if necessary), back, and repeat!
larry_g
oregon
Sweeper
I use on of the above linked sweepers. I do not blow dirt around the shop or out the door. Blowing just moves some of it into higher places and out the door just moves the mess from inside to outside where it is staged to come back in with the wind or the next rig pulling in. Just my way. At times the cleaning process starts with a scoop shovel.
lg
no neat sig line
Deltarat
I sweep out the shop and then if the weather is cold, I kept the house vac when we bought a new one, and run it over the floor. If it is warm outside I sweep and blow with the leaf blower.
spotco2
NW Georgia
Wait a minute...
You're supposed to clean the floor? :willy_nil
In the stealerships we used push brooms, regular straw brooms, air hoses, the sweeping compounds, mops and pressure washers.
With a push broom, we always push a few times, flip over and tap the back on the floor a few times, flip back over and push a little more.
It's almost impossible to get all of the dust up with just brooms or even air. Water is the easiest way after you get all the big stuff up.
skulldrinker
Bolingbrook, IL
The $5 push broom and the $5 dust pan from Harbor Freight. During a spring cleaning I use the air compressor. I have large sections of scrap carpet down also so once in a while I use the shop vac on them to get all the **** that drops from my repairs.
Vegaman_Dan
Pacific, WA
I've been tempted more than once to break out a mop and bucket to clean my coated floors. Though just spot cleaning any spills helps a lot.
I've got some overspray I need to take some mineral spirits to now that I think about it.
Jsf721
LI, NY
I sweep the big stuff, vacuum the dust and blow out the rest. Not all necessarily on tne same day :)
NUTTSGT
Northern Central Ohio
When I needed a new broom, the only thing Menard's had was a Libman multi-surface broom. I wanted a softer bristle brrom but it wasn't in the cards that day. There is a Harper distributer close by, maybe I need to go check them out, I know Harper has some good stuff.
When the floor needs a good cleaning, I break out the mop & bucket, some hot water and Simple Green.
